I have an app that is using the Basic Viewer template and it isnt allowing me to configure Location Search under the Search Settings. I can check it on and off but am given no layers to search on even though there are searchable layers in the map. Do I need to do anything to upgrade the app to the latest version of the template? It was made months ago but is heavily used so I do not want to recreate and have to distribute a new URL.
You may have already done this but if not be sure to edit the web map application settings to allow Find Locations "By Layer" (see attached screen shot). When you check the By Layer box it allows you to define which layers within the map are searchable and by which fields. Let me know if this helps or if it is something else. Good luck!
Unfortunately if I configure it there the search occurs before the filter is applied on the layer settings. I have some features definition queried out in the map for this particular app. I think its just a bug in AGOL because in another test app which I created this morning it allowed be to configure the search in app, now its not giving me the options anymore even though I used the same service in both. There should be little folder icons below the words Location Search but its saying there are no valid layers. Ill give it a rest for a while and try FF or IE instead of Chrome in a bit.
Yeah, looks like you are using the Search Settings for a widget so my suggestion is out. I haven't used that particular widget you are working with. Sorry I can't more helpful
Its the geocoder/search box built into the Basic Viewer template so I don't have much leeway to poke at it if I don't want to download the code and host it myself.
