I run a block of code that runs off of lost focus. It runs fine the first time, but then I try to set focus to a textbox(which appears not to work) so I click in the textbox and tab out. The lost focus event does not work that time? Why is that?
Here is the related code:
on(document.getElementById('ownerAddress'), 'focusout', checkAddress);
on(document.getElementById('ownerAddress'), 'focusin', getElementId);
function getElementId() {
node = document.activeElement.id;
function checkAddress() {
console.log(node);
var locator = new Locator("http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer");
//console.log(document.getElementById('ownerAddress').value);
//node = document.getElementById('ownerAddress');
node = document.getElementById(node);
// according to your service it takes Single Line
var params = {
"Single Line Input": node.value
locator.addressToLocations(params).then(function (addressCandidates) {
//console.log('success', addressCandidates);
//console.log(addressCandidates.length);
data = {
identifier: "id",
items: []
layout = [[
// {'name': 'FID', 'field': 'id', 'width': '50px'},//
{ 'name': 'Address', 'field': 'address', 'width': '200px' }
if (addressCandidates.length > 1) {
for (a = 0; a < addressCandidates.length; a++) {
// This is the address that should go into a grid cell
data.items.push(lang.mixin({ id: a + 1 }, { address: addressCandidates.address }));
console.log(addressCandidates.address);
console.log(addressCandidates);
items = arrayUtils.map(addressCandidates, function (result) {
console.log(result);
return result;
console.log(items);
console.log("Log" + data);
if (window.grid) {
Maingds
dojo.destroy('grid');
dijit.byId('grid').destroy(true);
registry.remove(dom.byId('gridDiv'));
store = new ItemFileWriteStore({ data: data });
grid = new DataGrid({
store: store,
structure: layout,
autoWidth: true,
autoHeight: false,
rowSelector: '20px'
// display grid
//document.getElementById("grid").style.display = "block";
//alert("hello " + addressCandidates.length);
// Show modal
if (addressCandidates.length >= 1) {
$("#myModal").modal("show");
$('#myModal').show(function () {
$(this).trigger('isVisible');
//registry.byId("grid").display=block;
grid.on("rowclick", onRowClickHandler);
//hookup the event
$('#myModal').bind('isVisible', isVisible);
var adresses = addressCandidates.map(function () {
return x.address;
//console.log(adresses);
else
alert("This address does not appear to be a city address. Please try again.");
document.getElementById(node).focus();
}).otherwise(function (err) {
console.log('somethings wrong', err);
//declare event to run when div is visible
function isVisible() {
/*append the new grid to the div*/
grid.placeAt("gridDiv");
/*Call startup() to render the grid*/
grid.startup();
function onRowClickHandler(evt) {
console.log(evt);
var clickedAddress = evt.grid.getItem(evt.rowIndex).address;
console.log(clickedAddress);
alert(clickedAddress);
// console.log(evt.explicitOriginalTarget.data);
