var identifyParams:IdentifyParameters = new IdentifyParameters(); identifyParams.returnGeometry = true; identifyParams.tolerance = 3; identifyParams.width = myMap.width; identifyParams.height = myMap.height; identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = myMap.extent; identifyParams.spatialReference = myMap.spatialReference; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.layerIds = [0];
undefined at com.esri.ags.script::IdentifyHelper/set myIds()
package com.esri.ags.script { public class IdentifyHelper { private var _myIds:Array; public function get myIds():Array { return myIds; } public function set myIds(value:Array):void { myIds = value; } } }
ArgumentError: Error #2025: The supplied DisplayObject must be a child of the caller. at flash.display::DisplayObjectContainer/getChildIndex() at mx.managers::SystemManager/getChildIndex() at mx.managers.systemClasses::ActiveWindowManager/mouseDownHandler()
public static var identify:IdentifyHelper = new IdentifyHelper; private function onItemClick(event):void { switch (this.selectedItem.name) { case "Zoning": identify.myIds = [4]; break; case "LUP - Area Comm Plan": identify.myIds = [5]; break; case "LUP - General Plan": identify.myIds = [6]; break; } }
protected function mapClickHandler(event:MapMouseEvent):void { clickGraphicsLayer.clear(); graphiclayer.clear(); var identifyParams:IdentifyParameters = new IdentifyParameters(); identifyParams.returnGeometry = true; identifyParams.tolerance = 3; identifyParams.width = map.width; identifyParams.height = map.height; identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = map.extent; identifyParams.spatialReference = map.spatialReference; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.layerIds = com.esri.ags.samples.LayerTOC.identify.myIds; var clickGraphic:Graphic = new Graphic(event.mapPoint, clickPtSym); clickGraphicsLayer.add(clickGraphic); identifyTask.execute(identifyParams, new AsyncResponder(myResultFunction, myFaultFunction, clickGraphic)); }
package com.esri.ags.script { public class IdentifyHelper { private var _myIds:Array; public function get myIds():Array { return this.myIds; } public function set myIds( value:Array ):void { this.myIds = value; } } }
private function onItemClick(event):void { switch (this.selectedItem.name) { case "Zoning": IdentifyHelper.myIds = [4]; break; case "LUP - Area Comm Plan": IdentifyHelper.myIds = [5]; break; case "LUP - General Plan": IdentifyHelper.myIds = [6]; break; } }
protected function mapClickHandler(event:MapMouseEvent):void { clickGraphicsLayer.clear(); graphiclayer.clear(); var identifyParams:IdentifyParameters = new IdentifyParameters(); identifyParams.returnGeometry = true; identifyParams.tolerance = 3; identifyParams.width = map.width; identifyParams.height = map.height; identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = map.extent; identifyParams.spatialReference = map.spatialReference; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.layerIds = IdentifyHelper.myIds; var clickGraphic:Graphic = new Graphic(event.mapPoint, clickPtSym); clickGraphicsLayer.add(clickGraphic); identifyTask.execute(identifyParams, new AsyncResponder(myResultFunction, myFaultFunction, clickGraphic)); }
public class IdentifyHelper { private var _myIds:Array; public function get myIds():Array { return this.myIds; } public function set myIds( value:Array ):void { this.myIds = value; } } /* in theory all your identify parameters could go here, if you desire a different look and feel for each layer */
switch (myString) { case "Rivers": identifyhelper.myIds = [0]; break; case "Lakes": identifyhelper.myIds = [1]; break; case "Plants": identifyhelper.myIds = [2]; break; }
identifyParams.layerIds = identifyhelper.myIds;
