override protected function commitProperties():void { super.commitProperties(); var featureLayer:FeatureLayer = hostComponent.featureLayer; var formattedAttributes:Object = hostComponent.formattedAttributes; var graphic:Graphic = hostComponent.graphic; var map:Map = hostComponent.map; var popUpInfo:PopUpInfo = hostComponent.popUpInfo; var validMediaInfos:Array = hostComponent.validPopUpMediaInfos; var geometry:Geometry = graphic ? graphic.geometry : null; var layerDetails:LayerDetails = featureLayer ? featureLayer.layerDetails : null; vGroup.removeAllElements(); //vGroup.addElement(ToggleLayers); if (popUpInfo){ if (popUpInfo.title){ titleText.text = StringUtil.substitute(popUpInfo.title, formattedAttributes); if (titleText.text){ vGroup.addElement(titleText); vGroup.addElement(titleLine); } } var htmlText:String; if (popUpInfo.description){ htmlText = StringUtil.substitute(popUpInfo.description, formattedAttributes); if (htmlText){ var descriptionText:Text = new PopUpText(); descriptionText.percentWidth = 100; descriptionText.styleSheet = textStyleSheet; cleanAndSetHtmlText(descriptionText, htmlText); //trace(descriptionText.htmlText); vGroup.addElement(descriptionText); } }else{ var descriptionForm:Form; //Added Code activities.removeAllElements(); //End Added Code for each (var fieldInfo:PopUpFieldInfo in popUpInfo.popUpFieldInfos){ //Added Code var AddFormItem:Boolean = true; //End Added Code if (fieldInfo.visible){ var formItem:FormItem = new FormItem(); formItem.label = fieldInfo.label || fieldInfo.fieldName; var label:Label; htmlText = formattedAttributes[fieldInfo.fieldName]; //Added Code var img:Image; switch(formItem.label){ case "Parking": case "Golf": case "Tennis": case "Restrooms": case "Soccer": case "Football": case "Basketball": case "Baseball": case "Fishing": case "Running": case "Skateboard":{ if(htmlText){ img = new Image(); img.source = "assets/images/" + htmlText; img.width = img.height = 20; activities.addElement(img); } AddFormItem = false; break; } } //End Added Code if (htmlText) { // convert attribute field values that just contain URLs into links var match:Array = htmlText.match(/^\s*((https?|ftp):\/\/\S+)\s*$/i); if (match && match.length > 0) { label = new Label(); htmlText = '<a href="' + match[1] + '" target="_blank">' + match[1] + "</a>"; } else { label = new PopUpText(); } cleanAndSetHtmlText(label, htmlText); label.selectable = true; label.styleSheet = this.textStyleSheet; label.width = 150; formItem.addChild(label); } if (!descriptionForm) { descriptionForm = new Form(); descriptionForm.percentWidth = 100; descriptionForm.horizontalScrollPolicy = ScrollPolicy.OFF; descriptionForm.verticalScrollPolicy = ScrollPolicy.OFF; descriptionForm.styleName = "formStyle"; } //Changed Code if(AddFormItem) descriptionForm.addChild(formItem); //End Changed Code } } if (descriptionForm) { vGroup.addElement(descriptionForm); } //Added Code if(activities.numElements >0) vGroup.addElement(activities) //End Added Code } //Add the red line to the Declarations <fx:Declarations> <!--- @private --> <mx:Text id="titleText" width="100%" fontWeight="bold"/> <!--- @private --> <s:Line id="titleLine" width="100%"> <s:stroke> <s:SolidColorStroke id="titleLineSymbol" color="black" weight="1"/> </s:stroke> </s:Line> <!--- @private --> <supportClasses:PopUpMediaBrowser id="mediaBrowser" width="100%" skinClass="com.esri.ags.skins.supportClasses.PopUpMediaBrowserSkin"/> <!--- @private --> <esri:AttachmentInspector id="attachmentInspector" width="100%" addEnabled="false" deleteEnabled="false"/> <!--- @private --> <mx:LinkButton id="zoomToButton" click="zoomToButton_clickHandler(event)" fontWeight="bold" label="{resourceManager.getString('ESRIMessages', 'zoomLabel')}"/> <s:TileGroup id="activities" orientation="rows" width="100%" /> </fx:Declarations>
