Hi
i am a beginer in programming. i am trying to create a drop down menu for my application, where on selecting a district the feature polygon should be highlighted and further mandal....
while loading it shows the error
ReferenceError: QueryTask is not defined
ReferenceError: query is not defined
here is the code.....where am i going wrong
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Popup</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
<style>
html, body, #map {
padding: 0;
margin: 0;
height: 100%;
/* Change color of icons to match bar chart and selection symbol */
.esriPopup.dark div.titleButton,
.esriPopup.dark div.titlePane .title,
.esriPopup.dark div.actionsPane .action {
color: #A4CE67;
/* Additional customizations */
.esriPopup.dark .esriPopupWrapper {
border: none;
.esriPopup .contentPane {
text-align: left;
.esriViewPopup .gallery {
margin: 0 auto;
</style>
<script src="http://js.arcgis.com/3.13/"></script>
<script>
var map;
require([
"esri/map",
"esri/dijit/Popup", "esri/dijit/PopupTemplate",
"esri/layers/FeatureLayer",
"esri/dijit/Search",
"esri/tasks/QueryTask",
"esri/tasks/query",
"esri/symbols/SimpleFillSymbol", "esri/Color",
"dojo/dom-class", "dojo/dom-construct", "dojo/on",
"dojox/charting/Chart", "dojox/charting/themes/Dollar",
"dojo/domReady!"
], function(
Map,
Popup, PopupTemplate,
FeatureLayer, Search,
SimpleFillSymbol, Color,
QueryTask, Query,
domClass, domConstruct, on,
Chart, theme
//The popup is the default info window so you only need to create the popup and
//assign it to the map if you want to change default properties. Here we are
//noting that the specified title content should display in the header bar
//and providing our own selection symbol for polygons.
var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
var popup = new Popup({
fillSymbol: fill,
titleInBody: false
}, domConstruct.create("div"));
//Add the dark theme which is customized further in the <style> tag at the top of this page
domClass.add(popup.domNode, "lighter");
map = new Map("map", {
basemap: "satellite",
center: [79.2, 18.10],
zoom: 8,
infoWindow: popup
var template = new PopupTemplate({
title: "TELANGANA PATTA APPLICANTS",
description: "Application No: {application_no} <br> <br>DISTRICT: {district_name1} <br><br>MANDAL: {mandal_name1}<br><br> VILLAGE: {village_name1} <br><br> OCCUPANT NAME: {name_of_the_occupant} <br><br>ADDRESS: {present_address} <br><br> Survey No.: {survey_no} <br><br> LAND EXTENT: {extent_of_land} <br>",
var featureLayer = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/elands/MapServer/0",{
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"],
infoTemplate: template
map.addLayer(featureLayer);
var featureLayer2 = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/elands/MapServer/2",{
outFields: ["*"]
map.addLayer(featureLayer2);
var featureLayer1 = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/elands/MapServer/1",{
outFields: ["*"]
map.addLayer(featureLayer1);
queryTask = new QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/elands/MapServer/2");
query = new Query();
query.returnGeometry = true;
query.outFields = ["*"];
function executeQueryTask(population) {
//set query based on what user typed in for population;
alert(population);
query.where = "MNAME = '" + population+"'";
//execute query
queryTask.execute(query,showResults);
function showResults(featureSet) {
//remove all graphics on the maps graphics layer
map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures = featureSet.features;
//Loop through each feature returned
for (var i=0, il=resultFeatures.length; i<il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = resultFeatures;
graphic.setSymbol(symbol);
//Set the infoTemplate.
graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
</script>
</head>
<body class="claro">
<form name="classic">
<select name="countries" size="4" onChange="updatecities(this.selectedIndex)" style="width: 150px">
<option selected>Select A DISTRICT</option>
<option value="1">ADILABAD</option>
<option value="2">KARIMNAGAR</option>
<option value="3">KHAMMAM</option>
<option value="4">MAHABUBNAGAR</option>
<option value="5">MEDAK</option>
<option value="6">NALGONDA</option>
<option value="7">NIZAMABAD</option>
<option value="8">RANGA REDDY</option>
<option value="9">WARANGAL</option>
<option value="10">HYDERABAD</option>
</select>
Mandals:
<select name="cities" size="4" style="width: 150px" onClick="executeQueryTask(this.options[this.options.selectedIndex].value);"> <!-- alert(this.options[this.options.selectedIndex].value) -->
</select>
</form>
<script type="text/javascript">
var countrieslist=document.classic.countries
var citieslist=document.classic.cities
var cities=new Array()
cities[0]=""
cities[1]=["ADILABAD ", " ASIFABAD ", " BAZARHATHNOOR ", " BEJJUR ", " BELA ", " BELLAMPALLE ", " BHAINSA ", " BHEEMINI ", " BOATH ", " CHENNUR ", " DAHEGAON ", " DANDEPALLE ", " DILAWARPUR ", " GUDIHATHNUR ", " ICHODA ", " INDERAVELLY ", " JAINAD ", " JAINOOR ", " JAIPUR ", " JANNARAM ", " KADDAMPEDDUR ", " KAGAZ NAGAR ", " KASIPET ", " KERAMERI ", " KHANPUR ", " KOTAPALLE ", " KOUTHALA ", " KUBEER ", " KUNTALA ", " LAXMANCHANDA ", " LOHESRA ", " LUXETTIPET ", " MAMDA ", " MANCHERIAL ", " MANDAMARRI ", " MUDHOLE ", " NARNOOR ", " NENNAL ", " NERADIGONDA ", " NIRMAL ", " REBBANA ", " SARANGAPUR ", " SIRPUR (T) ", " SIRPUR (U) ", " TALAMADUGU ", " TAMSI ", " TANDUR ", " TANUR ", " TIRYANI ", " UTNUR ", " VEMANPALLE ", " WANKDI"]
cities[2]=["BEJJANKI", "BHEEMADEVARPALLE", "BOINPALLE", "CHANDURTHI", "CHIGURUMAMIDI", "CHOPPADANDI", "DHARMAPURI", "DHARMARAM", "ELKATHURTHI", "ELLANTHAKUNTA", "GAMBHIRAOPET", "GANGADHARA", "GOLLAPALLE", "HUSNABAD", "HUZURABAD", "IBRAHIMPATNAM", "JAGTIAL", "JAMMIKUNTA", "JULAPALLE", "KAMALAPUR", "KAMANPUR", "KARIMNAGAR", "KATARAM", "KATHLAPUR", "KESAVAPATNAM", "KODIMIAL", "KOHEDA", "KONARAOPETA", "KORATLA", "MAHADEVPUR", "MALHARRAO", "MALLAPUR", "MALLIAL", "MANAKONDUR", "MANTHANI", "MEDIPALLE", "METPALLE", "MUSTABAD", "MUTHARAM MAHADEVPUR", "MUTHARAM MANTHANI", "ODELA", "PEDDAPALLE", "PEGADAPALLE", "RAIKAL", "RAMADUGU", "RAMAGUNDAM", "SAIDAPUR", "SARANGAPUR", "SIRSILLA", "SRIRAMPUR", "SULTANABAD", "THIMMAPUR", "VEENAVANKA", "VELGATOOR", "VEMULAWADA", "YELLA REDDI PETA"]
cities[3]=["ASWAPURAM", "ASWARAOPETA", "BAYYARAM", "BHADRACHALAM", "BONAKAL", "BURGAMPADU", "CHANDRUGONDA", "CHERLA", "CHINTHAKANI", "DAMMAPETA", "DUMMUGUDEM", "ENKURU", "GARLA", "GUNDALA", "JULURPAD", "KALLURU", "KAMEPALLE", "KHAMMAM RURAL", "KHAMMAM URBAN", "KONIJERLA", "KOTHAGUDEM", "KUSUMANCHI", "MADHIRA", "MANUGURU", "MUDIGONDA", "MULAKALAPALLE", "NELAKONDAPALLE", "PALAWANCHA", "PENUBALLI", "PINAPAKA", "SATHUPALLE", "SINGARENI", "TEKULAPALLE", "THALLADA", "THIRUMALAYAPALEM", "VEMSOOR", "VENKATAPURAM", "WAZEED", "WYRA", "YELLANDU", "YERRUPALEM"]
cities[4]=["ACHAMPETA", "ADDAKAL", "AIZA", "ALAMPUR", "AMANGAL", "AMRABAD", "ATMAKUR", "BALANAGAR", "BALMOOR", "BHOOTHPUR", "BIJINAPALLE", "BOMRASPETA", "CHINNA CHINTA KUNTA", "DAMARAGIDDA", "DEVARKADARA", "DHANWADA", "DHARUR", "DOULATABAD", "FAROOQNAGAR", "GADWAL", "GHANPUR", "GHATTU", "GOPALPETA", "HANWADA", "ITIKYAL", "JADCHERLA", "KALAWAKURTHY", "KESHAMPETA", "KODAIR", "KOILKONDA", "KOLLAPUR", "KONDANGAL", "KONDURG", "KOSGI", "KOTHAKONTA", "KOTHUR", "LINGAL", "MADDUR", "MADGUL", "MAGANOOR", "MAHABUBNAGAR", "MAKTHAL", "MALADAKAL", "MANOPADU", "MIDJIL", "NAGAR KURNOOL", "NARAYANPET", "NARVA", "NAWABPET", "PANGAL", "PEBBAIR", "PEDDAKOTHAPALLE", "PEDDAMANDADI", "TADOOR", "TALAKONDAPALLE", "TELKAPALLE", "THIMMAJIPETA", "UPPUNUNTHALA", "UTKOOR", "VANGOOR", "VEEPANGANDLA", "VELDANDA", "WADDEPALLE", "WANAPARTHY"]
cities[5]=["ALLADURG", "ANDOLE", "CHEGUNTA", "CHINNAKODUR", "DOULTHABAD", "DUBBAK", "GAJWEL", "HATHNOORA", "JAGDEVPUR", "JHARASANGAM", "JINNARAM", "KALHER", "KANGTI", "KOHIR", "KONDAPAK", "KONDAPUR", "KOWDIPALLI", "KULCHARAM", "MANOOR", "MEDAK", "MIRDODDI", "MULUGU", "MUNIPALLE", "NANGNUR", "NARAYANKHED", "NARSAPUR", "NYALKAL", "PAPANNAPET", "PATANCHERU", "PULKAL", "RAIKODE", "RAMACHANDRAPURAM", "RAMAYAMPET", "REGODE", "SADASIVPET", "SANGAREDDY", "SHANKARAMPET(A)", "SHANKARAMPET(R)", "SHIVAMPET", "SIDDIPET", "TEKMAL", "TOOPRAN", "WARGAL", "YELDURTHI", "ZAHIRABAD"]
cities[6]=["ALAIR", "ANUMULA", "ATMAKUR (S)", "ATMAKUR (M)", "BHUVANAGIRI", "BIBINAGAR", "BOMMALARAMARAM", "CHANDAM PET", "CHANDUR", "CHILKUR", "CHINTHA PALLE", "CHITYALA", "CHIVVEMLA", "CHOUTUPPAL", "DAMERACHERLA", "DEVARAKONDA", "GARIDE PALLE", "GUNDALA", "GUNDLA PALLE", "GURRAMPODE", "HUZURNAGAR", "JAJI REDDI GUDEM", "KANGAL", "KATTANGOOR", "KETHEPALLE", "KODAD", "M TURKAPALLE", "MARRI GUDA", "MATTAMPALLE", "MELLACHERVU", "MIRYALAGUDA", "MOTHEY", "MOTHKUR", "MUNAGALA", "MUNUGODE", "NADIGUDEM", "NAKREKAL", "NALGONDA", "NAMPALLE", "NARAYANAPUR", "NARKETPALLE", "NERED CHERLA", "NIDAMANUR", "NUTHANKAL", "PEDDA ADISERLAPALLE", "PEDDAVURA", "PENPAHAD", "POCHAMPALLE", "RAJAPET", "RAMANNAPETA", "SALIGOURARAM", "SURYAPET", "THIPPARTHI", "THIRUMALAGIRI", "THRIPURARAM", "THUNGA THURTHI", "VALIGONDA", "VEMULAPALLE", "YADAGIRIGUTTA"]
cities[7]=["ARMUR", "BALKONDA", "BANSWADA", "BHEEMGAL", "BHIKNUR", "BICHKUNDA", "BIRKOOR", "BODHAN", "DHARPALLE", "DICH PALLE", "DOMAKONDA", "GANDHARI", "JAKRANPALLE", "JUKKAL", "KAMAREDDY", "KAMMAR PALLE", "KOTGIRI", "LINGAMPET", "MACHAREDDY", "MADNUR", "MAKLOOR", "MORTAD", "NAGA REDDIPET", "NANDIPET", "NAVIPET", "NIZAM SAGAR", "NIZAMABAD", "NIZAMABAD (M)", "PITLAM", "RANJAL", "SADASIVANAGAR", "SIRKONDA", "TADWAI", "VARNI", "VELPUR", "YEDA PALLE", "YELLAREDDY"]
cities[8]=["BALANAGAR", "BANTARAM", "BASHEERABAD", "CHEVELLA", "DHARUR", "DOMA", "GANDEED", "GHATKESAR", "HAYATHNAGAR", "IBRAHIMPATAM", "IBRAHIMPATNAM", "KANDUKUR", "KEESARA", "KULKACHARLA", "MAHESWARAM", "MALKAJGIRI", "MANCHAL", "MARPALLE", "MEDCHAL", "MOINABAD", "MOMINPET", "NAWABPET", "PARGI", "PEDDEMUL", "PUDUR", "QUTHBULLAPUR", "RAJENDRANAGAR", "SAROORNAGAR", "SERLINGAMPALLY", "SHABAD", "SHAMIRPET", "SHAMSHABAD", "SHANKARPALLE", "TANDUR", "UPPAL", "VIKARABAD", "YACHARAM", "YELAL"]
cities[9]=["ATMAKUR", "BACHANNAPETA", "BHUPALPALLE", "CHENNARAOPET", "CHERIYAL", "CHITYAL", "DEVARUPPULA", "DHARMASAGAR", "DORNAKAL", "DUGGONDI", "ETURNAGARAM", "GEESUGONDA", "GHANAPUR", "GHANPUR(stn)", "GOVINDARAOPET", "GUDUR", "HANAMKONDA", "HASANPARTHY", "JANGAON", "KESAMUDRAM", "KHANAPUR", "KODAKANDLA", "KOTHAGUDEM", "KURAVI", "LINGALA GHANPUR", "MADDUR", "MAHABUBABAD", "MANGAPET", "MARIPEDA", "MOGULLAPALLE", "MULUG", "NALLABELLY", "NARMETTA", "NARSAMPET", "NARSIMHULAPET", "NEKKONDA", "NELLIKUDUR", "PALAKURTHI", "PARKAL", "PARVATHAGIRI", "RAGHUNATHA PALLE", "RAIPARTHY", "REGONDA", "SANGEM", "TADVAI", "THORRUR", "VENKATAPUR", "WARANGAL", "WARDHANNAPET", "ZAFFERGADH"]
cities[10]=["HYDERABAD"]
function updatecities(selectedcitygroup){
citieslist.options.length=0
if (selectedcitygroup>0){
for (i=0; i<cities[selectedcitygroup].length; i++)
citieslist.options[citieslist.options.length]=new Option(cities[selectedcitygroup].split("|")[0], cities[selectedcitygroup].split("|")[1])
</script>
<div id="map"></div>
</body>
</html>
