Im making an app which i have added some dynamic layers to the map, but for some reason i cannot put the :
infowindow (in onclick) and a tooltip (in mouseover).
Can anyone tells me what im doing wrong or provide any example of how to do this? (I already try using the examples in the Samples | ArcGIS API for JavaScript for infowindows)
It will be very usefull.
Thanks a lot
Im developing with reactjs (es6) , webpack srv and i put the arcgis_js_api in my working webpack server.
I separate the map in another javascript file
function mymap(){
var map;
return {
createMap(div){
map = new esri.Map(div, {
basemap: "topo",
center:[-71.2905, -33.1009],
zoom:9,
logo: false
return map;
getMap(){
return map;
onClick(){
map.on("click",(mouseEvent)=>{
return console.log("thinking on map onClick for infowindow");
export default mymap();The code for my component where i set up the map is:
import React from 'react';
import ReactDOM from 'react-dom';
import token from '../services/token-service';
import layers from '../services/layers-service';
import StatisticsToolbar from '../bundles/statistics-toolbar';
import mymap from '../services/map-service';
import MyGrid from '../bundles/myGrid';
class Interruptions extends React.Component {
constructor(){
super();
this.onClick = this.onClick.bind(this);
this.onClickToggle = this.onClickToggle.bind(this);
this.onClickStatistics = this.onClickStatistics.bind(this);
this.searchMassive = this.searchMassive.bind(this);
componentDidMount(){
var map = mymap.createMap("myMapDiv");
map.disableKeyboardNavigation();
var myDynamicSedLayer = new esri.layers.ArcGISDynamicMapServiceLayer(layers.read_dyn_layer_PO());
var myDynamicBTLayer2 = new esri.layers.ArcGISDynamicMapServiceLayer(layers.read_layer_BT());
var visibleLayers = [1];
myDynamicBTLayer2.setVisibleLayers(visibleLayers);
map.on("click",(evt)=>{
//TEMPLATE PARA MOSTRAR INFOWINDOW SUBESTACION DE DISTRIBUCION (0)
var chqSubestacionDistribucionTemplate = new esri.InfoTemplate();
chqSubestacionDistribucionTemplate.setTitle("<b>SSEE: ${ARCGIS.DBO.SED_006.codigo}</b>");
var chqSubestacionInfoContent =
"<div style=padding-top: 10px;>Nombre: ${ARCGIS.DBO.SED_006.nombre}<br></div>" +
"<div style=display:inline-block;width:8px;></div>"+
"<div style=padding-top: 10px;>Alimentador: ${ARCGIS.DBO.SED_006.alimentador}<br></div>"+
"<div style=padding-top: 10px;>Comuna: ${ARCGIS.DBO.SED_006.comuna}<br></div>"+
"<div style=padding-top: 10px;>ID Orden: ${ARCGIS.DBO.POWERON_ORDENES.id_orden}<br></div>"+
"<div style=display:inline-block;width:8px;></div>";
chqSubestacionDistribucionTemplate.setContent(chqSubestacionInfoContent);
// show info window
myDynamicSedLayer.setInfoTemplates({
0:{InfoTemplate: chqSubestacionDistribucionTemplate}
map.addLayer(myDynamicSedLayer,2);
map.addLayer(myDynamicBTLayer2,1);....
NOTE: My directoryFile is in the attachment.
