Is there any way to create a map point for a record in a FC without geocoding? I have a point FC which has records that have addresses and I need to get them on the map. The problem with geocoding is that the result would need to be stored in a different output location. I want to keep the features in the feature class - just create a spatial location for them as all of their attribute information is already in the FC.
Thanks in advance,
David
What is keeping you from from just adding the feature class? Are the XY values of the points coincident with the address location? Perhaps you can clarify what you want to do.
The feature class is a table which is already in ArcMap. The table has addresses and a few other fields but no XY values. The records were created by another user who entered them directly to the table and populated the attributes instead of first creating the feature on the map and then assigning attributes.
Well... That's a contradiction in terms; In arcgis you have a feature class or you have a table. You have a table of addresses, and the only to visualize the records in that table as points is to geocode them.
But you can edit the feature class and add records to the attribute table, right?
