I created a .tpkx file of some aerial photography using ArcGIS Pro 2.3. I chose the option .tpkx instead of .tpk as it looked like it might perform better based on the help menu explanation. I uploaded the .tpkx package to arcgis.com, and had it create a tile layer from it.
When I add the tile layer (projected to web mercator) to an arcgis.com map it will display just fine. However, if I move it to become the basemap layer of the map, then try using the map in the basemap widget of Web AppBuilder, it either does not display the map, or when I open the Arcgis.com map again, it says it is not a supported file type for basemaps.
I have used this same process before with the regular .tpk file. I am guessing the .tpkx file isn't supported then? I have searched ESRI help menus and all I can find about a .tpkx file is this:
- tpkx —The tiles are stored using CompactV2 storage format which provides better performance on network shares and cloudstore directories. This improved and simplified package structure type is supported by newer versions of the ArcGIS Platform such as ArcGIS Online 7.1, ArcGIS Enterprise 10.7 and ArcGIS Runtime 100.5.
Any suggestions? I am running it again as a normal .tpk file but it will take several hours to complete.
