Dear all,
We’ve prepared this storymap, using mainly feature services: http://speck.conabio.gob.mx/cruzada/OAX/pobreza/index.html
Now we observed the following issue: When you click any of the polygons and use the “zoom to” option in the pop-up window to focus on this polygons, you ´ll face the selected polygon with a simplified geometry (see figure below). Switch the topic on the same zoom level, and the geometry is rendered correctly again.
The geometry itself is correct – we have checked this on ArcGIS-Online. Moreover, the problem does not occur when you use other options of zooming (e.g. scroll).
Hence, it seems that the map loads a simplified geometry at the beginning which is not updated when you use the “zoom to” option in the pop-up, but is updated correctly when you zoom via scroll.
Any hints, why the issues occur and how we can solve it?
Thank you & best regards,
Flo
