What are the things to consider when processing Aerial Images to ensure that the result are correct? I need to combine thousands of Aerial Images into one. I have ArcGIS Desktop 10.2 to do this. Any tips and suggestions are highly appreciated. Thanks in advance.
Hello GIS Users, any suggestions please! Thanks!
Your initial question was somewhat vague. Are you needing to mosaic multiple images together? run image analysis on images? Are they already Georeferenced or do they need georeferencing?
If you could be a bit more specific about the project you are needing to do, it would help us find an answer.
I already have georeferenced aerial images and i need to mosaic those multiple images. I know the process of mosaicking using raster catalog but I am uncertain as to how i could verify that the position of said images are correct.
Thanks for answering Ian.
Hi friend,
Have you consider using Mosaic Dataset ? I'd start working with two first and then add two more to give you an idea.
More information can be found here :ArcGIS Help 10.1
I just worked on this with NAIP I am working on for the whole state of New Mexico 2009, 2011,2012, and 2014.
I am not sure if you are aware that there is another good site for you to read...
it is called GIS Stackexchange where everyone share their GIS problems.
I looked it up for your similiar situation and found a lot of good information...
The website is Geographic Information Systems Stack Exchange
Type Mosaic Dataset
Good luck.
Thank you so much Robert.
I'll try that website and look for possible solution on my problem.
