private function zoomToGraphics():void { var graphicProvider:ArrayCollection = gLayer.graphicProvider as ArrayCollection; var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(graphicProvider.toArray()); if (graphicsExtent){ Map.extent = graphicsExtent; Alert.show("Mheight: " + Map.extent.height + "\n Gheight: " + graphicsExtent.height + "\n " + "\n Mwidth: " + Map.extent.width + "\n Gwidth: " + graphicsExtent.width); } }
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <fx:Script> <![CDATA[ import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.utils.GraphicUtil; import mx.collections.ArrayCollection; protected function map_mapClickHandler(event:MapMouseEvent):void { var graphicProvider:ArrayCollection = gLayer.graphicProvider as ArrayCollection; var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(graphicProvider.toArray()); trace(graphicsExtent, graphicsExtent.width, graphicsExtent.height); map.extent = graphicsExtent; trace(map.extent, map.extent.width, map.extent.height) } ]]> </fx:Script> <esri:Map id="map" mapClick="map_mapClickHandler(event)"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:GraphicsLayer id="gLayer"> <esri:Graphic> <esri:WebMercatorMapPoint lon="10" lat="10"/> </esri:Graphic> <esri:Graphic> <esri:WebMercatorMapPoint lon="10" lat="50"/> </esri:Graphic> </esri:GraphicsLayer> </esri:Map> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" xmlns:mx="library://ns.adobe.com/flex/mx"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polygon; import com.esri.ags.utils.GraphicUtil; import com.esri.ags.geometry.Extent; import mx.controls.Alert; import mx.collections.ArrayCollection; protected function Map_mapClickHandler(event:MapMouseEvent):void { //allow user to enter size of poly desired if(tInput1.text == ""){ Alert.show("Please enter a number in the text input before clicking the map."); }else{ var size:int = Number(tInput1.text); var halfSize:Number = size/2; var center:MapPoint=Map.toMapFromStage(event.stageX, event.stageY); var botLeft:MapPoint = new MapPoint; //new mapPoint is assigned the same coor sys as the map botLeft.spatialReference=Map.spatialReference; //units defined by the spatial reference botLeft.x=center.x-halfSize; botLeft.y=center.y-halfSize*20; var botRight:MapPoint = new MapPoint; botRight.spatialReference=Map.spatialReference; botRight.x=center.x+halfSize; botRight.y=center.y-halfSize*20; var topRight:MapPoint = new MapPoint; topRight.spatialReference=Map.spatialReference; topRight.x=center.x+halfSize; topRight.y=center.y+halfSize*20; var topLeft:MapPoint = new MapPoint; topLeft.spatialReference=Map.spatialReference; topLeft.x=center.x-halfSize; topLeft.y=center.y+halfSize*20; var newPolygon:Polygon = new Polygon; newPolygon.spatialReference=Map.spatialReference; newPolygon.rings=[[botLeft, botRight, topRight, topLeft, botLeft]]; var newGraphic:Graphic = new Graphic; newGraphic.geometry=newPolygon; newGraphic.symbol=symbol1; gLayer.add(newGraphic); zoomToGraphics(); } } private function zoomToGraphics():void { var graphicProvider:ArrayCollection = ArrayCollection(gLayer.graphicProvider); var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(graphicProvider.toArray()); //graphicsExtent.spatialReference = Map.spatialReference; Map.extent = graphicsExtent; Alert.show("Map height: " + Map.extent.height + "\n gE height: " + graphicsExtent.height + "\n " + "\n Map width: " + Map.extent.width + "\n gE width: " + graphicsExtent.width); } protected function clearGraphics_clickHandler(event:MouseEvent):void { gLayer.clear(); } ]]> </fx:Script> <fx:Declarations> <esri:SimpleFillSymbol id="symbol1" style="solid" color="0xFF0000" alpha="0.3"> <esri:outline> <esri:SimpleLineSymbol style="solid" color="0x000000" width="1" /> </esri:outline> </esri:SimpleFillSymbol> </fx:Declarations> <s:BorderContainer id="mainBC" width="550" height="730" borderVisible="true" borderAlpha="1" borderColor="#FF0000" borderStyle="solid" borderWeight="3"> <s:layout> <s:VerticalLayout horizontalAlign="center" verticalAlign="middle" paddingTop="5"/> </s:layout> <s:Label text="Click the map to add a graphic" fontSize="15"/> <esri:Map id="Map" logoVisible="false" mapClick="Map_mapClickHandler(event)"> <esri:ArcGISTiledMapServiceLayer id="mapSvc" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:GraphicsLayer id="gLayer"/> </esri:Map> <s:TextInput id="tInput1" text="10000"/> <s:Button id="clearGraphics" label="Clear Graphics" click="clearGraphics_clickHandler(event)"/> </s:BorderContainer> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" xmlns:mx="library://ns.adobe.com/flex/mx"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polygon; import com.esri.ags.utils.GraphicUtil; import com.esri.ags.geometry.Extent; import mx.controls.Alert; import mx.collections.ArrayCollection; protected function Map_mapClickHandler(event:MapMouseEvent):void { //allow user to enter size of poly desired if(tInput1.text == ""){ Alert.show("Please enter a number in the text input before clicking the map."); }else{ var size:int = Number(tInput1.text); var halfSize:Number = size/2; var center:MapPoint=Map.toMapFromStage(event.stageX, event.stageY); var botLeft:MapPoint = new MapPoint; //new mapPoint is assigned the same coor sys as the map botLeft.spatialReference=Map.spatialReference; //units defined by the spatial reference botLeft.x=center.x-halfSize; botLeft.y=center.y-halfSize*Number(tInput2.text); var botRight:MapPoint = new MapPoint; botRight.spatialReference=Map.spatialReference; botRight.x=center.x+halfSize; botRight.y=center.y-halfSize*Number(tInput2.text); var topRight:MapPoint = new MapPoint; topRight.spatialReference=Map.spatialReference; topRight.x=center.x+halfSize; topRight.y=center.y+halfSize*Number(tInput2.text); var topLeft:MapPoint = new MapPoint; topLeft.spatialReference=Map.spatialReference; topLeft.x=center.x-halfSize; topLeft.y=center.y+halfSize*Number(tInput2.text); var newPolygon:Polygon = new Polygon; newPolygon.spatialReference=Map.spatialReference; newPolygon.rings=[[botLeft, botRight, topRight, topLeft, botLeft]]; var newGraphic:Graphic = new Graphic; newGraphic.geometry=newPolygon; newGraphic.symbol=symbol1; gLayer.add(newGraphic); zoomToGraphics(); } } private function zoomToGraphics():void { var graphicProvider:ArrayCollection = ArrayCollection(gLayer.graphicProvider); var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(graphicProvider.toArray()); //graphicsExtent.spatialReference = Map.spatialReference; Map.extent = graphicsExtent; Alert.show("Map height: " + Map.extent.height + "\n gE height: " + graphicsExtent.height + "\n " + "\n Map width: " + Map.extent.width + "\n gE width: " + graphicsExtent.width); } protected function clearGraphics_clickHandler(event:MouseEvent):void { gLayer.clear(); } ]]> </fx:Script> <fx:Declarations> <esri:SimpleFillSymbol id="symbol1" style="solid" color="0xFF0000" alpha="0.3"> <esri:outline> <esri:SimpleLineSymbol style="solid" color="0x000000" width="1" /> </esri:outline> </esri:SimpleFillSymbol> </fx:Declarations> <s:BorderContainer id="mainBC" width="550" height="500" borderVisible="true" borderAlpha="1" borderColor="#FF0000" borderStyle="solid" borderWeight="3"> <s:layout> <s:VerticalLayout horizontalAlign="center" verticalAlign="middle" paddingTop="5"/> </s:layout> <s:Label text="Click the map to add a graphic" fontSize="15"/> <esri:Map id="Map" logoVisible="false" mapClick="Map_mapClickHandler(event)"> <esri:ArcGISTiledMapServiceLayer id="mapSvc" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:GraphicsLayer id="gLayer"/> </esri:Map> <s:TextInput id="tInput1" text="10000"/> <s:TextInput id="tInput2" text = "20"/> <s:Button id="clearGraphics" label="Clear Graphics" click="clearGraphics_clickHandler(event)"/> </s:BorderContainer> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <s:layout> <s:VerticalLayout horizontalAlign="center" paddingBottom="10" paddingTop="10"/> </s:layout> <fx:Script> <![CDATA[ protected function button1_clickHandler(event:MouseEvent):void { map.extent = testExt; } ]]> </fx:Script> <s:Button click="button1_clickHandler(event)" label="Set Extent"/> <esri:Map id="map" width="500" height="600"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:GraphicsLayer> <esri:Graphic> <esri:WebMercatorExtent id="testExt" minlon="5" minlat="-80" maxlon="10" maxlat="80"/> <esri:symbol> <esri:SimpleFillSymbol color="red"/> </esri:symbol> </esri:Graphic> </esri:GraphicsLayer> </esri:Map> </s:Application>
