class ToolValidator: """Class for validating a tool's parameter values and controlling the behavior of the tool's dialog.""" def __init__(self): """Setup arcpy and the list of tool parameters.""" import arcpy self.params = arcpy.GetParameterInfo() print self.params def initializeParameters(self): self.params[1].category = "Feature Types" self.params[2].category = "Feature Types" self.params[3].category = "Feature Types" """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" return def updateParameters(self): if self.params[0].altered: if self.params[0].value == "Point": self.params[1].enabled = 1 self.params[2].enabled = 0 self.params[3].enabled = 0 elif self.params[0].value == "Line": self.params[1].enabled = 0 self.params[2].enabled = 1 self.params[3].enabled = 0 elif self.params[0].value == "Polygon": self.params[1].enabled = 0 self.params[2].enabled = 0 self.params[3].enabled = 1 """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parmater has been changed.""" return def updateMessages(self): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return
What am I doing wrong? I'm completely stumped!
