<layers onlythese="false>" <layer> <name>Sanitary Structure</name> <fields> <field alias="Type" name="TYPE"/> <field alias="Outlet Direction" name="OUTLET_DIR"/> </fields> <zoomscale>15000</zoomscale> <forcescale>true</forcescale> </layer> </layers>"
<?xml version="1.0"?> <configuration> <betareturngeometryfix>false</betareturngeometryfix> <identifylayeroption>visible</identifylayeroption> <identifytolerance>5</identifytolerance> <defaultzoomscale>5000</defaultzoomscale> <keepidentifyactive>true</keepidentifyactive> <returngeometryforzoom>true</returngeometryforzoom> <enablelineselect>true</enablelineselect> <enableextentselect>true</enableextentselect> <enablepolyselect>true</enablepolyselect> <enablemouseovergraphicsinfo>true</enablemouseovergraphicsinfo> <enablemouseoverrecordinfo>false</enablemouseoverrecordinfo> <usemaptime>false</usemaptime> <infoautoclosemilliseconds>2000</infoautoclosemilliseconds> <!-- 2 seconds --> <autoactivatedtool>mappoint</autoactivatedtool> <!-- possible values are extent or polygon or mappoint or polyline or nothing --> <excludebasemaps>true</excludebasemaps> <disablepopuplinks>false</disablepopuplinks> <lables> <zoom2message>Click to Zoom to Point</zoom2message> <idenifylabel>Identify</idenifylabel> <resultslabel>Results</resultslabel> <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel> <pointlabel>Identify by Point</pointlabel> <linelabel>Identify by Line</linelabel> <rectlabel>Identify by Rectangle</rectlabel> <polylabel>Identify by Polygon</polylabel> <clearlabel>Clear</clearlabel> <loadinglabel>Loading...</loadinglabel> <removeresultmessage>Remove Result</removeresultmessage> <idfrom>Identify From</idfrom> <noresultsfoundlabel>No Results Found</noresultsfoundlabel> <resultsfoundlabel>Results Found</resultsfoundlabel> </lables> <useproxy> <!-- http://web3.adams-county.com/ArcGIS/rest/services/Sewage/MapServer/ --> </useproxy> <layers onlythese="false"> <layer> <name>Sanitary Structure</name> <fields> <field alias="Type" name="TYPE"/> <field alias="Outlet Direction" name="OUTLET_DIR"/> </fields> <zoomscale>15000</zoomscale> <forcescale>true</forcescale> </layer> </layers> <symbols> <simplefillsymbol style="solid" alpha="0.4" color="0x44ccb"> <outline alpha="0.8" color="0x448ccb" width="2"/> </simplefillsymbol> <simplemarkersymbol style="circle"alpha="0.8" color="0x448ccb" angle="0" yoffset="0" size="12"> <outline style="solid" alpha="0.8" color="0xffffff" width="1"/> </simplemarkersymbol> <picturemarkersymbol width="30" yoffset="0" xoffset="0" height="30" url="assets/images/i_info.png"/> <simplelinesymbol alpha="0.8" color="0x448ccb" width="2"/> </symbols> </configuration>
