I'm using JavaScript API 4.5 and my application is using webmap. I want to highlight the feature that the user clicks on (polygon) and clear the current one and highlight the new one every time the user clicks on a new feature.
I created a GraphicsLayer for it and use removeall() to remove all the graphics before draw the new one. This works fine until I zoom the map. When I zoom the map all the graphics come back and I can't figure out where they are stored. I checked the graphics layer and there is always one graphic in it which is the most recent selected feature.
<SPAN class="token function">highlightFeature</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> theComponent <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> graphicsLayerMap<SPAN class="punctuation token">;</SPAN>
theComponent<SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>webMaps<SPAN class="punctuation token">[</SPAN>theComponent<SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>currentMap<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">.</SPAN>items<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">===</SPAN> <SPAN class="string token">'graphics'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
graphicsLayerMap <SPAN class="operator token">=</SPAN> layer<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// SimpleFillSymbolProperties only necessary because of tight coupling of object types. Normally outside of Angular/Webpack we wouldn't need a fake SimpleFillSymbolProperties class</SPAN>
<SPAN class="keyword token">let</SPAN> symbolProps <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbolProperties</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'none'</SPAN><SPAN class="punctuation token">,</SPAN>
outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">197</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">let</SPAN> highlightSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>symbolProps<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphic<SPAN class="punctuation token">.</SPAN>symbol <SPAN class="operator token">=</SPAN> highlightSymbol<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>graphicsLayerMap <SPAN class="operator token">!==</SPAN> undefined<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// not the first time click on the map</SPAN>
graphicsLayerMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphicsLayerMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// if this is the first click on this map, add a graphicsLayer to the map</SPAN>
<SPAN class="comment token">// add graphic to GraphicsLayer</SPAN>
<SPAN class="keyword token">let</SPAN> graphicsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
graphics<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>graphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
listMode<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'hide'</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>webMaps<SPAN class="punctuation token">[</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN>currentMap<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphicsLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> Any help would be appreciated!
