I have a map service with one layer and three related tables. I can successfully execute queries against my related tables and return values. The problem I am having is that I only get the field names and not their aliases. How can I access field aliases of the tables?
Andrew,
You use the esri request class to get the json for the layer and that will have the fields and aliases array
require([ "esri/request", ... ], function(esriRequest, ... ) { var layerUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0"; var layersRequest = esriRequest({ url: layerUrl, content: { f: "json" }, handleAs: "json", callbackParamName: "callback" }); layersRequest.then( function(response) { console.log("Success: ", response.fields); }, function(error) { console.log("Error: ", error.message); }); ... });<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Am I correct to assume I will have to do this for every related table? Then, store the array and query it by the field name to get the alias?
Yes
