I am having problems with arcgis pro crashing on projects that have been opened several times and that have imagery background. I don't have this problem in ArcMap. I can create a new project and it works but after the project has been saved and opened several times and if the project has imagery (WMTS) the project crash will crash on open. I have sent in error report. I have an NVIDIA graphics card with an integrated intel UHD 630.
Would you happen to have link for tech support or a best way to contact, do
I need to go through my sales rep?
Gary... Control Panel, Add/Remove programs, select ArcGIS and when you get the option select 'Repair'
If it has worked and it isn't now, then it might new to be repaired. If not... Tech Support... they may have more options and access to other tools to do a full assessment.
It looks like I should be able to run the software. I did not have problem with crashes until recently.
Here is the report, I did not have a problem with crashes until now.
Yes that i correct, 2.3.2 is the version of Pro I have,
How does it fair on the system requirements?
ArcGIS Pro 2.3 system requirements—ArcGIS Pro | ArcGIS Desktop especially the
Check your computer's ability to run ArcGIS Pro 2.3. link
Are you running ArcGIS Pro 2.3.2?
