Hi all!
I am attempting to create a schematic diagram from some water network data (points and lines).
I have created a Geometric Network using the wizard. I then worked through the Schematics tutorial to create a Schematics dataset and import my feature classes.
When I head back to the MXD to Generate a Schematic Diagram, I select all the options in teh form and give the diagram a name, then hit OK and a new Data Frame is created. Inside are all my layers, however, nothing is showing in the data frame.
Have I setup my data incorrectly? Where am I going wrong?
Any help with this is much appreciated!
I have attached the MXD and the FGDB.
Kind regards
Tim
