I'm using the Network Analyst extension to get some route between multiple origins and destinations using the closest facility analysis. I have 2 questions relating to this:
1) is there any way you can add the attributes of the shape file that you load the facilities and incidents from.
2) the routes that are created appear as a single line. Is there anyway of getting an output which as the actual links that are used?
Also... is there a way of getting the actual routes through a network when using the OD Matrix feature in Network Analyst?
