Hello Guys, I need to perform Mann Kendall test on 5 series raster data yearly basis, from 2007 to 2011.
if need to iterate pixel by pixel on raster cell values for calculating the sign. How can i do it... Below is code but i have problem with numpy...
import arcpy
import numpy
from arcpy import env
env.workspace = r"D:\PythonProject\Data"
rasterlist = arcpy.ListRasters()
for raster in rasterlist:
print raster
n = len(rasterlist)
pairs = (n * ( n - 1)) / 2
print "Pairs to be formed: ", pairs
def pairsRasters(raster1, raster2):
print raster1, " - ", raster2
inRas1 = arcpy.Raster(raster1)
lowerLeft1 = arcpy.Point(inRas1.extent.XMin,inRas1.extent.YMin)
#cellSize = inRas.meanCellWidth
my_array1 = arcpy.RasterToNumPyArray(inRas1,nodata_to_value=0)
inRas2 = arcpy.Raster(raster2)
lowerLeft2 = arcpy.Point(inRas2.extent.XMin,inRas2.extent.YMin)
my_array2 = arcpy.RasterToNumPyArray(inRas2,nodata_to_value=0)
for current in reversed(rasterlist):
for previous in rasterlist:
if current == previous:
pass
elif current > previous:
pairsRasters(current, previous)
else:
pass
Suppose the two raster of similar extent, i need to calculate difference, if it's greater than 1 the value store in output raster would be 1, if less than 1 the value would be -1 and else zero. How can i iterate on pixel by pixel of two rasters. so i can save it into new raster. That's it..
Column 1
| Column 2 | Column 3 | Column 4 | Column 5 |
| 50 | 25 | 98 | 102 | 98 |
| 122 | 98 | 10 | 210 | 100 |
| 57 | 66 | 92 | 21 | 10 |
| 98 | 45 | 255 | 9 | 59 |
| 58 | 98 | 17 | 31 | 54 |
Message was edited by: Ahsan Abbas
