I am using Arc10 SP4.I have a script completed for Parcel Noticing, it asks the user to input one parcel number and then runs through the script. We sometimes have to select multiple parcels for noticing.How would I go about starting a script using an excel file or text file that contains a list of parcel numbers? I want to create a script that allows the user the ability to select a file that contains a list of parcel numbers, have the script create a list that can be used in python to do a multiple selection. layer = arcpy.GetParameterAsText(0) apnlist = arcpy.GetParameterAsText(1) mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames (mxd, "LAYERS")[0]What data type parameter property should i use? ie, string or fileOnce this is determined, how do I go about turning that input into a list that I can use to create a selection?I am assuming it is going to be a for loop like this:for apn in apnlist: selstring = """TAG = '{0}'""".format(apn) arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION", selstring)
