I am having some issues when doing a layerView.queryExtent in 4.17 - it is always returning 0,0 for xmin,ymin. If you simply change the JS API back to 4.16 it works fine. I am using EPSG:7856 for basemap and featurelayer if that makes any difference.
4.17 Console:
XMin: 0, YMin: 0, XMax: 496267.40614137735, YMax: 7044933.36744386
4.16 Console:
XMin: 484190.3556723228, YMin: 7034270.401998081, XMax: 496267.40614137735, YMax: 7044933.36744386
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.17/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/WebMap"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>WebMap<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>id<SPAN class="punctuation token">:</SPAN><SPAN class="string token">"997b15031351498d9266a664f7843a8a"</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> featureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>url<SPAN class="punctuation token">:</SPAN><SPAN class="string token">"https://services3.arcgis.com/NvTosUQn3ZE5keno/arcgis/rest/services/big_data_test/FeatureServer/0"</SPAN><SPAN class="punctuation token">,</SPAN>outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>popup<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>dockEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>dockOptions<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>breakpoint<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenLayerView</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>layerView<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
layerView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"updating"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>val<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>val<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
layerView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryExtent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"XMin: "</SPAN> <SPAN class="operator token">+</SPAN> response<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>xmin <SPAN class="operator token">+</SPAN> <SPAN class="string token">","</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" YMin: "</SPAN> <SPAN class="operator token">+</SPAN> response<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>ymin <SPAN class="operator token">+</SPAN> <SPAN class="string token">","</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" XMax: "</SPAN> <SPAN class="operator token">+</SPAN> response<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>xmax <SPAN class="operator token">+</SPAN> <SPAN class="string token">","</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" YMax: "</SPAN> <SPAN class="operator token">+</SPAN> response<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>ymax<SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
