My apologies if this has been discussed in an earlier thread. I found similar threads, but none that answered my question.
I have collected GPS data using a Trimble GeoXH running ArcPad 10 with GPScorrect. I am still on ArcMap 10.0 and using GPS Analyst for post processing. My question is about choosing a base station for differential correction. In the differential correction wizard, there is a list of base stations to choose from. There are several base stations with a prefix of "CORS" and several base stations with a prefix of "TxDOT." For instance, there is a CORS Boerne station, and a TxDOT Boerne station. Could anyone explain the difference between these two? I believe these are the same base station (yes?). However, when I process my data against the CORS station, and then against the TxDOT station, the resulting points are 3 feet apart. I have looked at the data sheets from the CORS website for this station and it says that the coordinates are in NAD83 and ITRF00. So...which one is it? I was wondering if perhaps data corrected against the CORS base station is in ITRF00 and data corrected against the TxDOT base station is in NAD83?
I have attached a picture of some of my gps data points. The pink dots were corrected against the CORS Boerne base station, and the yellow dots were corrected against the TxDOT Boerne base station. The pink and yellow dots are about 3 feet apart.
I have also attached a picture of the base station list from the differential correction wizard. Notice the top two stations in the list: TxDOT Boerne and CORS Boerne.
I have set up my personal geodatabase in State Plane, NAD83, and I have chosen the WGS84 to NAD83_5 translation. I understand that the raw GPS data from the .ssf file is in WGS84, and that is why a translation must be chosen. I'm just not sure if my final data (after post processing) is in NAD83 or ITRF00 (depending on which base station I use).
My goal is to end up with data that is in NAD83.
I hope this makes sense. Any help would be greatly appreciated.
