Hello!
I have 30 rasters showing the slope for 30 years and I am trying to create a time series animation by using animation tool. However I am trying to find a way for each year to be appeared during the animation. I can't enable the time of the layers (there is no "time" option in properties) and subsequently I can not enable the time slider. Is there anything else I could try for having the time step included in the animation? Thank you in advance.
Can you share how you created your mosaic raster dataset (what configuration parameters did you use)?
I tried to create a mosaic dataset and then to add my rasters to this mosaic dataset without success since I receive the error "ERROR 999999" "No mosaic dataset item selected".
I think the best way to do this is to create a Mosaic Raster Dataset and add a field with a date (or two field with from and to date) and then you can enable time on your Mosaic Raster Dataset.
