I am trying to create a map in ArcGIS Pro in which you can click each individual polygon and then have the pop-up show an image of that area. Am I going to have to make each polygon its own layer in order to give each polygon its own separate pop-up? Or is there a way for me to set different images in the pop-ups for each separate polygon? Or is there a way I can add the image hyperlinks to the attribute table and then have the popup show the image (NOT the link)?
Hi, you can do it by putting the image URLs in the attribute table, as you suggested. Then configure the layer pop-ups like this:
Now you should see the unique images associated with your features in the pop-ups.
Tim
Excellent guidance! Thank you!
