I am trying to apply an SQL-funktion within the "Extract by Attributes"-Tool of ArcGIS.
I have a Table of 27.000 rows and 2+8 columns. I would like to select only those rows, where the event field=1 happens only 3 times in all. Values within those columns are 1, 2, 3 or 4.
The tool already provides the select funktion part, there after:
<SPAN class="pun">(</SPAN><SPAN class="kwd">CASE</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">WHEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"1984"</SPAN><SPAN class="pln"> </SPAN><SPAN class="pun">=</SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">THEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">ELSE</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">0</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">END</SPAN><SPAN class="pln"><BR /></SPAN><SPAN class="kwd">AND</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">CASE</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">WHEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"1986"</SPAN><SPAN class="pln"> </SPAN><SPAN class="pun">=</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">THEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">ELSE</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">0</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">END</SPAN><SPAN class="pln"><BR /></SPAN><SPAN class="kwd">AND</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">CASE</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">WHEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"1987"</SPAN><SPAN class="pln"> </SPAN><SPAN class="pun">=</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">THEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">ELSE</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">0</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">END</SPAN><SPAN class="pln"><BR /></SPAN><SPAN class="kwd">AND</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">CASE</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">WHEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"1991"</SPAN><SPAN class="pln"> </SPAN><SPAN class="pun">=</SPAN><SPAN class="lit">1</SPAN><SPAN class="kwd">THEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">ELSE</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">0</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">END</SPAN><SPAN class="pln"><BR /></SPAN><SPAN class="kwd">AND</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">CASE</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">WHEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"2000"</SPAN><SPAN class="pln"> </SPAN><SPAN class="pun">=</SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">THEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">ELSE</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">0</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">END</SPAN><SPAN class="pln"><BR /></SPAN><SPAN class="kwd">AND</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">CASE</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">WHEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"2003"</SPAN><SPAN class="pln"> </SPAN><SPAN class="pun">=</SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">THEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">ELSE</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">0</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">END</SPAN><SPAN class="pln"><BR /></SPAN><SPAN class="kwd">AND</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">CASE</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">WHEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"2006"</SPAN><SPAN class="pln"> </SPAN><SPAN class="pun">=</SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">THEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">ELSE</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">0</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">END</SPAN><SPAN class="pln"><BR /></SPAN><SPAN class="kwd">AND</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">CASE</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">WHEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"2011"</SPAN><SPAN class="pln"> </SPAN><SPAN class="pun">=</SPAN><SPAN class="lit">1</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">THEN</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">ELSE</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">0</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">END</SPAN><SPAN class="pun">)</SPAN><SPAN class="pln"><BR /></SPAN><SPAN class="pun">>=</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">3</SPAN>
The SQL statment is not excepted by the ArcGIS-tool. So something must be wrong here.
Greatefull for any ideas!
