Good Morning All,
I'm having a small issue configuring Larry Stouts Print Plus widget for WAB. I know Larry has taken a new job and does not really do regular updates to the widget and/or manage the forums for the widget any more but has anyone configured the scale bar into feet\meters instead of miles\kilometers? I really like what the print plus widget does with showing the print extent but without a good scale bar I cant really implement it in the application that I have created. I would imagine it has to be in the printplus.js file as I couldn't find anything within the config.json file but if any of you have any knowledge of this matter it would be very much appreciated.
Thank You,
Mike
Hi Michael. Did you ever get an answer to this or figure it out? I am having the same issue.
i did not. did you? i ended up creating a custom print service and using that with the updated print widget inside of WAB and while i cant see extents, its preforming fine and getting the users an accurate print
