I was following your example located here (Display military symbols with a dictionary renderer) in order to display Military Symbols based on the DictionaryRenderer. I get an error when attempting to Open the Symbol Style as follows:
SymbolStyle ss = await SymbolStyle.OpenAsync(@D:\Source\MapEngine\ESRI\mil2525d.stylx); DictionarySymbolStyle dss = ss as DictionarySymbolStyle;
The first line executes properly, but the second line fails ( assigns a null value) when assigning the SymbolStyle to the DictionaryStyle. I downloaded the styles from here: (http://solutions.arcgis.com/defense/help/military-symbology-styles/)
Am I missing something here? I am on 100.1 of the .NET SDK.
Robert,
Calling as below, I am able to see all the information related to that "mil2525d" symbol properties. I am using your stylx for testing.
var dss = await DictionarySymbolStyle.OpenAsync("mil2525d", @<folder_path>\mil2525d.stylx); Console.WriteLine(dss.TextFieldNames[0].ToString());
result: "additionalinformation"
DictionarySymbolStyle.OpenAsync Method
Hope that helps.
Nagma
I have the same issue after downgrading, which I expected after your last message. I will create a small standalone app and see if I can get it to work. I will let you know what I find.
Interesting. I am at a loss. Trying to think of what I may have incorrect that would cause a simple assignment to result in a null. I would understand of the first one failed
Hi Robert,
I downloaded you file from the link and I used 100.1 .Net API and I don't see any issue. Even the size of the two files are different, both of those works without any issue at my side.
Your file was different, but I got the same result. I am on 100.1 of the API. I may try downgrading to 100.0 to see if I get the same results.
I have Runtime Qt 100 installed, the file "mil2525d.stylx" comes with the installation. So I grabbed the file and used your code in .Net application. it works for me. Not sure whether .stylx file is corrupted. Attached is the file for your reference.
