What is the best way to lazy load a feature layer for a map? In my application, I have a map and handful of layers, some are turned off by default on launch. These feature service layers that are off by default I would like to delay loading until the user clicks that layer's on/off check box. Is this possible within the ArcGIS Online JS API? The solution I've brainstormed so far is to set the layer's url to an empty feature service when the layer is first instantiated. Inside the checkBox.on("change") function I would change the url to the correct feature service url, refresh() the layer, then proceed with the rest of the code that handles the layer rendering and tables. I don't want to reinvent the wheel when possible, so I'm looking for a documented or better way of handling this while I roll my own solution.
