Option Explicit Sub Test() 'highlight the first layer's workspace in the Source contentsview Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Dim pFLayer As IFeatureLayer Set pFLayer = FindLayer(pMxDoc.FocusMap, "MyLayer") If pFLayer Is Nothing Then MsgBox "layer not found" Exit Sub End If Dim pDS As IDataset Set pDS = pFLayer.FeatureClass Dim pCV As IContentsView Dim l As Long For l = 0 To pMxDoc.ContentsViewCount - 1 If pMxDoc.ContentsView(l).Name = "Source" Then Set pCV = pMxDoc.ContentsView(l) Exit For End If Next l If Not pCV Is Nothing Then Set pMxDoc.CurrentContentsView = pCV pCV.SelectedItem = pDS.Workspace End If End Sub Function FindLayer(pMap As IMap, s As String) As ILayer Set FindLayer = Nothing If pMap.LayerCount = 0 Then Exit Function End If Dim pEnumLayer As IEnumLayer Set pEnumLayer = pMap.Layers Dim pLayer As ILayer Set pLayer = pEnumLayer.Next Do Until pLayer Is Nothing If UCase(pLayer.Name) = UCase(s) Then Set FindLayer = pLayer Exit Do End If Set pLayer = pEnumLayer.Next Loop End Function
