I'm getting a ReferenceError "results is not defined" on the queryTask.execute:
<SPAN class="comment token">//first, check to see if a workplan boundary exists </SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>workplanId<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> queryUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsomewebsite%2Fsomeagssite%2Frest%2Fservices%2Ffolder%2Fservicename%2FFeatureServer%2F0" target="_blank">https://somewebsite/someagssite/rest/services/folder/servicename/FeatureServer/0</A><SPAN>"</SPAN></SPAN>
<SPAN class="keyword token">var</SPAN> queryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN>queryUrl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"workplanId ='"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>workplanId <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">debugger</SPAN><SPAN class="punctuation token">;</SPAN>
queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>workplanCheckValue <SPAN class="operator token">=</SPAN> results<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"workplanCheck value is: "</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>workplanCheckValue<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I need to set this.workplanCheckValue to the number of features returned from the queryTask.
Any assistance appreciated!
