Hi
I have login issues with my Workflow manager. I have different login usernames and passwords for my workflow manager and arcgis online account. When I tried to login my WF javascript viewer with Workflow Manager login (created in Workflow Manager Administrator) it said "wmindex wants to access your ArcGIS Online account information" and did not take me to the wmviewer page. I do not use any services from arcgis online. Any ideas how to solve this issue ?
Thank you,
Hi Lalaine,
Attached is my config file. Could you please take a look and let me know which lines I should change ?
Thank you very much!
Hi Helen,
If you have Workflow Manager Server secured behind ArcGIS Portal, you will need to configure your JavaScript viewer to use portal authentication. There is a "Set up security using ArcGIS Portal Authentication" section in the JavaScript viewer README.pdf file that should help you with setup.
Hope that helps.
Lalaine
I use 10.4, and yes my WM server secured behine ArcGIS Portal.
May I have your email address please ?
I can open a ticket # with support if you want me to.
Thank you for your help.
Please answer the following questions so we can better help you.
- What version of Workflow Manager Server / JavaScript viewer are you using?
- Is your Workflow Manager Server secured behind ArcGIS Portal or ArcGIS Server via tokens?
- Are you sharing your Workflow Manager Server as an ArcGIS Online service?
- How have you configured security for the Workflow Manager Javascript viewer (windows, token, portal)?
If you could share your AppConfig.js file, we can help debug the issue.
Workflow Manager Team
