Please help.....
What code changes are necessary to make the popup feature attribute table of the Edit Widget and Smart Editor Widget draggable? I was able to do this with normal popups within the Foldable Theme but not with the editors attribute popup.
Rich
Rich,
Here is how to do that. In the Widget.js.
(lines 32 and 37 make sure to add the comma on line 31 too):
<SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">'dojo/_base/declare'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/_base/lang'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/_base/array'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/_base/html'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/i18n!esri/nls/jsapi'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/on'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/query'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/json'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/Deferred'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/aspect'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/promise/all'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dijit/_WidgetsInTemplateMixin'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/BaseWidget'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/MapManager'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/LayerInfos/LayerInfos'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/dijit/LoadingShelter'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/utils'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/portalUrlUtils'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/SelectionManager'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'jimu/Role'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'esri/dijit/editing/Editor'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'esri/dijit/Popup'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/editing/TemplatePicker"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/renderers/jsonUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/form/Button"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"./utils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'./FilterEditor'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'./RelatedRecordsEditor'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'dojo/dnd/Moveable'</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>declare<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">,</SPAN> array<SPAN class="punctuation token">,</SPAN> html<SPAN class="punctuation token">,</SPAN> esriBundle<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> query<SPAN class="punctuation token">,</SPAN> Json<SPAN class="punctuation token">,</SPAN> Deferred<SPAN class="punctuation token">,</SPAN> aspect<SPAN class="punctuation token">,</SPAN> all<SPAN class="punctuation token">,</SPAN> _WidgetsInTemplateMixin<SPAN class="punctuation token">,</SPAN> BaseWidget<SPAN class="punctuation token">,</SPAN> MapManager<SPAN class="punctuation token">,</SPAN> LayerInfos<SPAN class="punctuation token">,</SPAN> LoadingShelter<SPAN class="punctuation token">,</SPAN> jimuUtils<SPAN class="punctuation token">,</SPAN> portalUrlUtils<SPAN class="punctuation token">,</SPAN> SelectionManager<SPAN class="punctuation token">,</SPAN> Role<SPAN class="punctuation token">,</SPAN> Editor<SPAN class="punctuation token">,</SPAN> Popup<SPAN class="punctuation token">,</SPAN> TemplatePicker<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN> rendererJsonUtils<SPAN class="punctuation token">,</SPAN> Button<SPAN class="punctuation token">,</SPAN> editUtils<SPAN class="punctuation token">,</SPAN> FilterEditor<SPAN class="punctuation token">,</SPAN> RelatedRecordsEditor<SPAN class="punctuation token">,</SPAN> Moveable<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Add lines 8 - 11:
startup<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">inherited</SPAN><SPAN class="punctuation token">(</SPAN>arguments<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>editPopup <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Popup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"class"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"jimu-widget-edit-infoWindow"</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>root<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> handle <SPAN class="operator token">=</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".title"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>editPopup<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> dnd <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Moveable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>editPopup<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> handle<SPAN class="punctuation token">:</SPAN> handle <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>loading <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LoadingShelter</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> hidden<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>loading<SPAN class="punctuation token">.</SPAN><SPAN class="token function">placeAt</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank You!
Works perfect!
