Hi All,the ToolValidator documentation says:As a Value object does not support string manipulation, use the Value object's value property whenever a string is to be manipulated or parsed. The code sample uses the os.path.dirname method to return the directory from a dataset.
if self.params[0].value:
workspace = os.path.dirname(self.params[0].value.value)
However, the following works fine:workspace = os.path.dirname(self.params[0].value)
My question are,1. Has anyone encountered a situation where they DID have to use self.params[0].value.value and self.params[0].value wouldn't work?2. Is this working because I'm running 10.2? Does it work for those of you that have 9.3, 10.0, and 10.1? I have a dummy script tool with 1 param. The code below is for debugging outside the script tool. It also works inside the script tool (I set a second param to that value to check it in the script tool). Here's a complete script to test this:import arcpy, os
arcpy.ImportToolbox(r"C:\temp\sandbox.tbx")
params = arcpy.GetParameterInfo("myScriptTool")
params[0].value = "C:/Temp/data.shp"
class ToolValidator:
def __init__(self):
import arcpy
self.params = arcpy.GetParameterInfo()
def initializeParameters(self):
# (initializeParameters code here)
return
def updateParameters(self):
# (updateParameters code here)
print os.path.dirname(self.params[0].value)
return
def updateMessages(self):
# (updateMessages code here)
return
# Call routine(s) to debug
validator = ToolValidator()
validator.updateParameters()
validator.updateMessages()It runs successfully and prints:C:/TempThe documentation is about midway through the following page:http://resources.arcgis.com/en/help/main/10.2/index.html#/Programming_a_ToolValidator_class/00150000000v000000/
