private void OnSaveFeatures(Editor.EditEventArgs e) { FeatureLayer fLayer = null; foreach (Editor.Change c in e.Edits) { if (c.Layer.ID.ToUpper() == "ProjectPolys".ToUpper()) { fLayer = c.Layer as FeatureLayer; if (c.Graphic != null) { if (c.Graphic.Attributes.ContainsKey("Expiration_Date")) { if (c.Graphic.Attributes["Expiration_Date"] != null) ((FeatureLayer)c.Layer).Graphics.Remove(c.Graphic); } } else Debug.WriteLine("null graphic!"); } } if (fLayer != null) fLayer.Update(); // this is a workaround }
private void FeatureLayer_EndSaveEdits(object sender, EndEditEventArgs e) { if(e.Results== null|| e.Results.UpdateResults == null) return; FeatureLayer layer = sender as FeatureLayer; foreach (var item in e.Results.UpdateResults) { Graphic graphic = layer.Graphics.Where(g =>(int) g.Attributes[layer.LayerInfo.ObjectIdField] ==(int) item.ObjectID).First(); //TODO: your code goes here } }
