I am trying to use a Text Widget with dynamic content that has HTML format tags, the content is displayed as a simple text without interpreting the format tags.
Is there a way to enforce formatting the text with the tags inside the text widget ?
Sample of raw formatted Dynamic Content which is displayed as is in the Text widget:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>p</SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">='</SPAN><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Marketing Name : <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN>AAAA<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Location:<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN> AAAA<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>p</SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">='</SPAN><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Description:<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN> AAAA <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>p</SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">='</SPAN><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Building Units and Area:<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN> AAAA<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>p</SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">='</SPAN><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Development Type:<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN> AAAAA<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Formatted Output
Marketing Name : AAAA
Description: AAAA
Building Units and Area: AAAA
Development Type: AAAAA
