I would like to calculate a centre point of a polygon, so that when I generate a circle buffer around the point it will touch the boundaries of my polygon from two sides along the diameter of a polygon. So actually I would like to find the polygon diameter centre. Functions such as Feature to Point or Calculate Geometry are not giving the results I need, because they do not calculate a centroid of a polygon that is allowing to generate a circle around the polygon that touch the polygon at least in two opposite vertexes.
I've found the answer: Minimum Bounding Geometry (Data Management)
I would also suggest using Feature to Point and have it generate centers (Inside
