I have a question regarding Edit Widget Edit widget—Web AppBuilder for ArcGIS | ArcGIS in WebApp Builder. I tried to add to my application an editable layer (point shapefile). I tried to do this on several ways (including creating a new map with editable layer). However, Edit Widget still does not work, it's showing me that I do not have any editable layer in my application. Does anyone know what can be wrong in my application, or with my data? I have organization account with publisher privileges. Thanks in advance!
Karolina,
You would have to make the layer in the web map editable and then re-add it to your WAB project. I just tested this and I could see the same message that you are seeing displayed.
Regards,
Tom
Is it possible that you have disable the editing for that layer in your web map?
Dear Tom,
Thanks for your answer. I changed the editing options in my layer properties and now it works.
Best regards,
Karolina
Excellent! I am very glad that resolved your problem!
Best Regards,
I am having trouble getting the WebApp Builder to recognise an editable layer.
I have added the Notes layer into the map from an ESRI REST service (with Feature Access on). In a Flex viewer I can add an Edit widget successfully and edit this service, but if I try it in the WAB it just says there are no editable layers.
Here's what it looks like in the Map. I can't find any enable/disable editing options in the menu.
Any suggestions?
Cheers
Keith
Further note to the above:
The ESRI REST service is a secure service that I have to provide a login for. Does this affect it?
cheers
Keith,
Are you certain that you have added the feature service to your web map and not the map service? Only the feature service will have the ability to do editing. The map service will not.
