I have a grid I'm creating that needed to be sorted, and also be able to save the grid to a CSV file and retain the sort I have on the grid. The grid is created in the results handler of queryTask. At this point, I simply run sort on the field I want and the grid looks fine. But that's a sort on the grid, not on the underlying data. grid = new (declare([Grid, ColumnHider, DijitRegistry, ColumnResizer]))({ id:"myGrid', columns: gridcolumns, store: currentMemory }); grid.startup(); grid.sort('NAME');Next I have a button that will allow the user to save this information to a CSV. It's getting created into the same container the grid is, so I can pass the argument of the grid name to it. var saveButton = new Button({ label: "Save List", onClick: function(){ saveGridCSV(grid); } }, "btnSave"); registry.byId("gridContainer").addChild(saveButton); registry.byId("gridContainer").addChild(grid); Within my saveGridCSV, I'm going back to the store of the grid and using it to get the values formatted for the CSV. //functions for saving to Excel function saveGridCSV(gridData){ var fName; if (gridData) { var gridLength = gridData.store.data.length; dataArray.length = 0; fieldNames.length = 0; var fieldValue = ""; var gridColumns = gridData.columns; var fieldHeaders = ["ID", "County", "Acres Treated", "Pct Area Treated", "Pct Change 2002-2007"]; for (var col in gridColumns) { fieldNames.push(col); } var lastCol = fieldNames.length -1; var lastField = fieldNames[lastCol]; dataArray.push(fieldHeaders.toString()+ " \n"); // dataArray.push(fieldNames.toString()+ " \n"); var gridStore = gridData.store; //steps through each record, pushes the values into an array that is formatted for CSV compatibility for (var i = 0; i < gridLength; i++) { var gridRow = gridStore.data; arrayUtils.forEach(fieldNames, function(fieldName){ fieldValue = gridRow[fieldName]; var stringValue = String(fieldValue); if (stringValue.indexOf(",") > 0) { //removes any commas from data stringValue = stringValue.replace(/,/g, " "); } if (stringValue.indexOf('\'') != -1 || stringValue.indexOf('\"') != -1) { //removes any slashes from data // console.log ("Data has a slash in it. Not sure of this section of the code!"); if (stringValue.indexOf('\"') != -1) { stringValue = stringValue.replace("\"", "\"\""); } stringValue = "\"" + stringValue + "\""; } if (fieldName == lastField) { dataArray.push(stringValue + " \n");//adds a new line when value is from the last field } else { dataArray.push(stringValue);//otherwise just adds the value } }); }//one row pushed to array var data = dataArray.join(); var inputData = data.replace(/\n,/g, "\n");//some clean up to get rid of the leading commas in the data submitCSVprint(gridData.id, inputData); } else { //nothing to save alert ("Error saving data."); } }This is working well, except that I still want the data sorted on my NAME field and now it's not. The sorting I performed early was on the grid, not on the underlying Memory.My question is, how do I sort the Memory instead so the CSV output matches what the user sees in the grid?
