I may already know the answer to this question but I thought I would ask the board just to confirm or reaffirm what I think.
I have a GNSS receiver which I want to use to collect elevation readings out in the field. Everything is set up and working correctly but if you have worked in Collector and used a GNSS receiver to collect data then you may have notice in the top right corner above your web map there is text that tells you when your GPS receiver is connected and what accuracy you are getting.
My question is does this GPS accuracy reading tell you how far off you are standing from your actual position or how far off your elevation reading is from the actual elevation?
