Is it possible to create a vector basemap .vtpk file with a transparent background?
My scenario is that I will want to create and load several vector basemap files into the same map. I have an ArcGIS Runtime mapping application with both basemap layers and operational layers, and there are points, lines, and polygons among both the basemap and operational layers. Cartographically, I need points on top of lines on top of polygons, so I need to mix my basemap and operational layers. The top to bottom Z order in other words needs to be ...
- - operational layer points,
- - basemap points,
- - operational layer lines,
- - basemap lines,
- - operational layer polygons, and then lastly
- - basemap polygons.
If I want to use vector basemaps then that makes 3 basemap .vtpk files I'll package into an mmpk. The catch is that ArcGIS Pro is forcing a white background layer for my vector basemaps, and the transparency symbol option doesn't seem to be available for the background layer in the p12\resources\styles\root.json file. That white background is blocking everything below my basemap point layer.
Is there a way to make that white background either missing or transparent for vector tile basemaps?
-Reed
