I am trying to project a layer into the web mercator projection used for the basemaps on ESRI online. I created the layer using Arcmap and I am trying to use the Project tool in this program to convert from WGS84 to Web mercator. I am having problems locating the Web mercator transformation in Arcmap. I can find mercator but not Web mercator. I understand that the two projections are different and my layer will not be aligned properly on the basemap if I use the mercator projection. Any assistance would be greatly appreciated.
Alan
Alan Wheeler,
Hello and good morning! Thank you for reaching out.
Might you be looking for the Web Mercator (auxiliary sphere)? If so, this is located within Projected Coordinate Systems > World > WGS 1984 Web Mercator (auxiliary sphere).
Let me know if this helps out! I look forward to your response.
Cheers,
Joe
Brilliant! Thank you so much. That projection is being added to my favorites.
