Hi,I am writing an extension for ArcMap using ArcObjects and VB.Net. As part of this extension I would like to access the �??Feature Class to Feature Class�?? geoprocessing tool using ArcObjects. Using the example in http://edndoc.esri.com/arcobjects/9.2/CPP_VB6_VBA_VCPP_Doc/COM/gp/Using%20Geoprocessing%20Tools%20in%20VB.pdf as a guide, I have managed to come up with the code below. This code however causes ArcMap to crash at the GP.Execute line.I have read the help file for this tool which suggests that the �??in_features�?? and �??out_path�?? need to be of types IFeatureLayer and IWorkspace respectively. Unfortunately I don�??t know how to set the properties correctly for this interface. http://resources.esri.com/help/9.3/arcgisdesktop/com/gp_toolref/conversion_tools/feature_class_to_feature_class_conversion_.htmAlso am I correct in setting the optional parameters to Nothing? Or should I not declare/set these at all?To start with I�??m just looking to go from SHP to SHP, but ultimately the goal will be SHP to SDE.Can anyone help me out?Thanks. Rob. Private Sub btnOK_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnOK.Click
Dim GP As IGeoProcessor = New GeoProcessor
'Dim gp As ESRI.ArcGIS.Geoprocessor.Geoprocessor = New ESRI.ArcGIS.Geoprocessor.Geoprocessor
'Declare variables for input
Dim in_features As String
Dim out_path As String
Dim out_name As String
Dim where_clause As String
Dim field_mapping As String
Dim config_keyword As String
'Define the input/output parameter
in_features = "C:\temp\roads.shp"
out_path = "C:\temp"
out_name = "aaa.shp"
where_clause = Nothing
field_mapping = Nothing
config_keyword = Nothing
'Declare and set a variant array
Dim parameters As IVariantArray
parameters = New VarArray
'Populate the variant array with
parameters.Add(in_features)
parameters.Add(out_path)
parameters.Add(out_name)
parameters.Add(where_clause)
parameters.Add(field_mapping)
parameters.Add(config_keyword)
'GP.FeatureclassToFeatureclass_conversion(in_features, out_path, out_name)
GP.Execute("FeatureclassToFeatureclass_conversion", parameters, Nothing)
End Sub
