I am trying to use the POST process to update the JSON for a feature service on ArcGIS Online. A detailed procedure on this process can be found here: https://blogs.esri.com/esri/arcgis/2014/10/19/updating-hosted-feature-services-in-arcgis-online/#comment-11263
I am trying to change the field editable to true in the following JSON.
"name" : "FACILITYID",
"type" : "esriFieldTypeString",
"alias" : "Facility Identifier",
"sqlType" : "sqlTypeOther",
"length" : 20,
"nullable" : true,
"editable" : false, <--- CHANGE TO true
"domain" : null,
"defaultValue" : null
Everything seems to run okay. I don't get any response only a blank page with the name of the layer
The change does not stick in the feature service howerver.
Any ideas?Published with ArcMAP 10.4.1 and Windows 7.
Thank you,
James
