Start Drawing Show measurement window (a floating window) Attach drawing object to variable Move mouse to draw segments Take drawing object variable and simplify using geometry service Run a length check on the current segment to display length Complete Drawing (onDrawEnd) Measurement window disappears
Is there a way to take the segments of a polygon as they are being drawn and display their measurement? I know that the measurement widget exists, however that's its own entity and separate from drawing a polygon. And so far I've been unable to find a method in which I can capture the current drawing object to run the geometry service against. Any suggestions or hints would be appreciated. If there was an event listener that could be attached which returned the current drawing object, I could then get the segment length from that
