Xcode 3.2iOS SDK 4.2ArcGIS for iOS SDK 2.0I have lines in a comma-separated text file that I am reading into AGSPoints then putting the AGSPoints into AGSGraphics. The lines contain X and Y values. I push each AGSGraphic into an AGSGraphicsLayer. The problem is the AGSGraphic items are displaying at 0,0 on the map. Stepping through the code, the correct X and Y values are in myGraphicArray and are in myGraphicsLayer. Here is the code. Thank you for any help.MapView.h
#import <UIKit/UIKit.h>
#import "ArcGIS.h"
@interface MapView : UIViewController {
AGSMapView *_mapView;
AGSSimpleMarkerSymbol *myMarkerSymbol;
AGSGraphicsLayer *myGraphicsLayer;
@property (nonatomic, retain) IBOutlet AGSMapView *mapView;
- (void)loadPointsOnMap;
@end
MapView.m#import "MapView.h"
#import "GPS1AppDelegate.h"
#import "TextFileMgmt.h"
@implementation MapView
@synthesize mapView = _mapView;
- (id)initWithNibName:(NSString *)nibNameOrNil bundle:(NSBundle *)nibBundleOrNil
self = [super initWithNibName:nibNameOrNil bundle:nibBundleOrNil];
if (self) {
// Custom initialization
myMarkerSymbol = [[AGSSimpleMarkerSymbol alloc] init];
myMarkerSymbol = [AGSSimpleMarkerSymbol simpleMarkerSymbol];
myMarkerSymbol.color = [UIColor blueColor];
// create a graphics layer
myGraphicsLayer = [[AGSGraphicsLayer alloc] init];
myGraphicsLayer = [AGSGraphicsLayer graphicsLayer];
return self;
- (void)didReceiveMemoryWarning
// Releases the view if it doesn't have a superview.
[super didReceiveMemoryWarning];
// Release any cached data, images, etc that aren't in use.
#pragma mark - View lifecycle
-(void)viewDidLoad
// get extent of points in current file including user's location
// zoom to the new extent
[super viewDidLoad];
AGSTiledMapServiceLayer *tiledLayer = [[AGSTiledMapServiceLayer alloc]
initWithURL:[NSURL URLWithString:@"http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"]];
[self.mapView addMapLayer:tiledLayer withName:@Aerial Basemap];
[tiledLayer release];
NSLog(@mapView: %@", self.mapView.spatialReference);
// call local method to place points on map.
[self loadPointsOnMap];
- (void)viewDidUnload
[super viewDidUnload];
// Release any retained subviews of the main view.
// e.g. self.myOutlet = nil;
- (BOOL)shouldAutorotateToInterfaceOrientation:(UIInterfaceOrientation)interfaceOrientation
// Return YES for supported orientations
return (interfaceOrientation == UIInterfaceOrientationPortrait);
-(void)loadPointsOnMap
// alloc and init an instance of the TextFileMgmt class.
TextFileMgmt *textFileMgmt1 = [[TextFileMgmt alloc] init];
// run the parseTextFile method.
[textFileMgmt1 parseTextFile];
// now the points array should be filled with dictionary entries.
// feed each point into an AGSPoint object array.
NSMutableArray *myMarkerPointArray = [[NSMutableArray alloc] init];
NSLog(@textFileMgmt1 dict_x_long = %@", [textFileMgmt1.points valueForKey:@dict_x_long]);
for ( NSDictionary *item in textFileMgmt1.points )
AGSPoint *myPoint = [[AGSPoint alloc] init];
myPoint = [AGSPoint pointWithX:[[item valueForKey:@dict_x_long] doubleValue]
y:[[item valueForKey:@dict_y_lat] doubleValue]
spatialReference:self.mapView.spatialReference];
[myMarkerPointArray addObject:myPoint];
[myPoint release];
NSLog(@myMarkerPointArray contains: %@", myMarkerPointArray);
// once this for loop completes, we have an NSMutableArray holding AGSPoint instances.
// feed each AGSPoint from the myMarkerPoint array into an AGSGraphic object array.
NSMutableArray *myGraphicArray = [[NSMutableArray alloc] init];
for ( AGSPoint *item in myMarkerPointArray )
AGSGraphic *myGraphic = [[AGSGraphic alloc] init];
myGraphic = [AGSGraphic graphicWithGeometry:item
symbol:myMarkerSymbol
attributes:nil
infoTemplateDelegate:nil];
[myGraphicArray addObject:myGraphic];
[myGraphic release];
NSLog(@myGraphicArray contains: %@", myGraphicArray);
// once this for loop completes, we have an array of AGSGraphic instances.
// send the AGSGraphic array to an AGSGraphicsLayer.
for ( AGSGraphic *item in myGraphicArray )
NSLog(@item contains: %@", item);
// myGraphicsLayer was created in the init method.
[myGraphicsLayer addGraphic:item];
// our content should be ready for the map so add the layer.
NSLog(@myGraphicsLayer: %@", myGraphicsLayer);
[self.mapView addMapLayer:myGraphicsLayer withName:@Graphics Layer];
[myGraphicsLayer dataChanged];
[myGraphicsLayer release];
- (void)dealloc
self.mapView = nil;
[super dealloc];
@end
