private void GeoprocessorTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.GPExecuteCompleteEventArgs args) { btnPoint.IsEnabled = true; MessageBox.Show(args.Results.OutParameters.Count().ToString()); }
dg1.ItemsSource = gpLayer.FeatureSet.Features;
<sdk:DataGridTextColumn Binding="{Binding Path=Attributes[OID]}" Header="OID"/>
I think this guide doc might help: Geoprocessing task—ArcGIS API for Silverlight | ArcGIS for Developers
<sdk:DataGrid AutoGenerateColumns="True" Height="236" HorizontalAlignment="Left" Margin="12,52,0,0" Name="dg1" VerticalAlignment="Top" Width="476"> <sdk:DataGrid.Columns> <!--<sdk:DataGridTextColumn Binding="{Binding Path=OID}" SortMemberPath="OID" Header="OID"/>--> <!--<sdk:DataGridTextColumn Binding="{Binding Path=LossDt}" SortMemberPath="LossDt" Header="LossDt"/>--> <!--<sdk:DataGridTextColumn Binding="{Binding Path=FREQUENCY}" SortMemberPath="FREQUENCY" Header="FREQUENCY"/>--> <sdk:DataGridTextColumn Binding="{Binding MEAN_LossA}" SortMemberPath="MEAN_LossA" Header="MEAN_LossA"/> <!--<sdk:DataGridTextColumn Binding="{Binding Path=SUM_LossAm}" SortMemberPath="SUM_LossAm" Header="SUM_LossAm"/>--> <!--<sdk:DataGridTextColumn Binding="{Binding Path=MEAN_ExpAm}" SortMemberPath="MEAN_ExpAm" Header="MEAN_ExpAm"/>--> <!--<sdk:DataGridTextColumn Binding="{Binding Path=SUM_ExpAmt}" SortMemberPath="SUM_ExpAmt" Header="SUM_ExpAmt"/>--> </sdk:DataGrid.Columns> </sdk:DataGrid>
public interface HailData {} public class HailAttributes : HailData { //public double OID; //public string LossDt; // public double FREQUENCY; public string MEAN_LossA; //public double SUM_LossAm; //public double MEAN_ExpAm; //public double SUM_ExpAmt; } public string MEAN_LossA { get { return MEAN_LossA; } } private void GeoprocessorTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.GPExecuteCompleteEventArgs e) { try { this.dg1.ItemsSource = null; foreach (GPParameter gpParameter in e.Results.OutParameters) if (gpParameter.Name == "output_dbf") { GPRecordSet gpLayer = gpParameter as GPRecordSet; List<HailData> theList = new List<HailData>(); foreach (Graphic feature in gpLayer.FeatureSet.Features) { //MessageBox.Show(feature.Attributes["MEAN_LossA"].ToString()); theList.Add(new HailAttributes() { //OID = Convert.ToDouble(feature.Attributes["OID"]), //LossDt = feature.Attributes["LossDt"].ToString(), //FREQUENCY = Convert.ToDouble(feature.Attributes["FREQUENCY"]), MEAN_LossA = feature.Attributes["MEAN_LossA"].ToString(), //SUM_LossAm = Convert.ToDouble(feature.Attributes["SUM_LossAm"]), //MEAN_ExpAm = Convert.ToDouble(feature.Attributes["MEAN_ExpAm"]), //SUM_ExpAmt = Convert.ToDouble(feature.Attributes["SUM_ExpAmt"]), }); } MessageBox.Show(theList.Count().ToString()); this.dg1.ItemsSource = theList; } btnPoint.IsEnabled = true; } catch (OverflowException oEx) { MessageBox.Show(oEx.Message); btnPoint.IsEnabled = true; } catch (FormatException fEx) { MessageBox.Show(fEx.Message); btnPoint.IsEnabled = true; } catch (Exception ex) { MessageBox.Show(ex.Message + " stacktrace:" + ex.StackTrace); btnPoint.IsEnabled = true; } }
foreach (GPParameter gpParameter in e.Results.OutParameters) if (gpParameter.Name == "output_dbf") { GPRecordSet gpLayer = gpParameter as GPRecordSet; MessageBox.Show(gpLayer.FeatureSet.Count().ToString()); dg1.ItemsSource = gpLayer.FeatureSet.Features; }
Geoprocessor geoprocessorTask = sender as Geoprocessor; geoprocessorTask.GetResultDataCompleted += GeoprocessorTask_GetResultDataCompleted; geoprocessorTask.Failed += GeoprocessorTask_Failed; geoprocessorTask.GetResultDataAsync("j0ecca8fcfee3406ba977cb29b53d09dd", "output");
foreach (GPParameter gpParameter in e.Results.OutParameters) { GPFeatureRecordSetLayer gpLayer = gpParameter as GPFeatureRecordSetLayer; foreach (Graphic graphic in gpLayer.FeatureSet.Features) { graphicsLayer.Graphics.Add(graphic); } }
private void Geoprocessor_JobCompleted(object sender, JobInfoEventArgs e) { Geoprocessor geoprocessorTask = sender as Geoprocessor; geoprocessorTask.GetResultDataCompleted += GeoprocessorTask_GetResultDataCompleted; geoprocessorTask.Failed += GeoprocessorTask_Failed; geoprocessorTask.GetResultDataAsync(e.JobInfo.JobId, "output"); } private void GeoprocessorTask_GetResultDataCompleted(object sender, GPParameterEventArgs e) { GraphicsLayer graphicsLayer = MapApplication.Current.Map.Layers["MyResultGraphicsLayer"] as GraphicsLayer; GPFeatureRecordSetLayer gpLayer = e.Parameter as GPFeatureRecordSetLayer; MessageBox.Show(gpLayer.FeatureSet.Count().ToString()); foreach (Graphic graphic in gpLayer.FeatureSet.Features) { graphicsLayer.Graphics.Add(graphic); } MessageBox.Show(graphicsLayer.Count().ToString()); this.dg.GraphicsLayer = graphicsLayer; btnPoint.IsEnabled = true; } private void GeoprocessorTask_Failed(object sender, TaskFailedEventArgs e) { MessageBox.Show("Geoprocessing service failed: " + e.Error); btnPoint.IsEnabled = true; }
GraphicsLayer does not need to be part of map if there is no geometry.
GPFeatureRecordSetLayer gpLayer = e.Parameter as GPFeatureRecordSetLayer; foreach (Graphic graphic in gpLayer.FeatureSet.Features) { }
Results: Messages: �?� esriJobMessageTypeInformative: Executing (HailAnalysis): HailAnalysis "Feature Set" "100 Miles" �?� esriJobMessageTypeInformative: Start Time: Wed May 23 11:06:24 2012 �?� esriJobMessageTypeInformative: Executing (Buffer): Buffer "Feature Set" \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\Buffer.shp "100 Miles" FULL ROUND NONE # �?� esriJobMessageTypeInformative: Start Time: Wed May 23 11:06:24 2012 �?� esriJobMessageTypeInformative: Succeeded at Wed May 23 11:06:25 2012 (Elapsed Time: 1.00 seconds) �?� esriJobMessageTypeInformative: Executing (Clip): Clip \agsResources\ArcSDE.sde\ArcSDE.A10ID.HailClaims \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\Buffer.shp \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\HailClaims_Clip.shp # �?� esriJobMessageTypeInformative: Start Time: Wed May 23 11:06:25 2012 �?� esriJobMessageTypeInformative: Reading Features... �?� esriJobMessageTypeInformative: Cracking Features... �?� esriJobMessageTypeInformative: Assembling Features... �?� esriJobMessageTypeInformative: Succeeded at Wed May 23 11:06:25 2012 (Elapsed Time: 0.00 seconds) �?� esriJobMessageTypeInformative: Executing (Summary Statistics): Statistics \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\HailClaims_Clip.shp \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\HailClaims_Clip_Statistics.dbf "LossAmt MEAN;ExpAmt MEAN;LossAmt SUM;ExpAmt SUM" LossDt �?� esriJobMessageTypeInformative: Start Time: Wed May 23 11:06:25 2012 �?� esriJobMessageTypeInformative: Succeeded at Wed May 23 11:06:25 2012 (Elapsed Time: 0.00 seconds) �?� esriJobMessageTypeInformative: Executing (Sort): Sort \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\HailClaims_Clip_Statistics.dbf \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\HailClaims_Clip_Statistics_S.dbf "FREQUENCY DESCENDING" UR �?� esriJobMessageTypeInformative: Start Time: Wed May 23 11:06:25 2012 �?� esriJobMessageTypeInformative: Succeeded at Wed May 23 11:06:25 2012 (Elapsed Time: 0.00 seconds) �?� esriJobMessageTypeInformative: Executing (Table Select): TableSelect \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\HailClaims_Clip_Statistics_S.dbf \arcgisserver\arcgisjobs\gptools_gpserver\j1ef0965a68274e9e8f798b023f3ea66e\scratch\scratch.gdb\Ouput "OID >= 5" �?� esriJobMessageTypeInformative: Start Time: Wed May 23 11:06:25 2012 �?� esriJobMessageTypeInformative: Succeeded at Wed May 23 11:06:26 2012 (Elapsed Time: 1.00 seconds) �?� esriJobMessageTypeInformative: Succeeded at Wed May 23 11:06:26 2012 (Elapsed Time: 2.00 seconds)
