We used WMX in ArcMap in a daily basis and want to establish a migration path to ArcGIS Pro. As part of our evaluation I set a Workflow Connection in AG Pro without major problems but I'm not able to see current AOIs in the Map. Is there any considerations or configuration changes needed for Pro? I haven't found any related documentation about it.
Any help is appreciated.
We have the same issue and have narrowed it down to only occurring when you include extended properties in your query. The AOI's appear fine if your query only includes properties that are available in the jtx.jobs table, such as job number, date, stage etc. I am not sure if this issue has been reported to Esri yet but we are also very interested in a solution or some sort of work around.
Xiaomeng Zheng, attached the log file. Don't see any specific errors...
It seems to be a map loading issue for me. I see you have totally 302 jobs in the current job query and your AOI map should be just loaded properly. Any error in your log?
You probably need to update the log level from default 3 to 5 to capture details.
Meggie
Thanks for the feedback Meggie. Job description in Pro says it has LOI Defined, but no LOI shows.
Pro shall work the same way as the Workflow Manager client. The AOI function is still supported in Pro with the same configuration in the Workflow manager administrator. Would you please check your job's bookmark in Pro and see if the AOI bookmark existing?
