I have been attempting to query all features in a layer and just return one field. Is this allowed? I cannot get it to work with any of my map services, but examples I have looked at in the API reference documentation do not always specify where clauses or objectIds to query, so that leads me to think it's allowed.
I am trying to run this snippet, but every time I run it, it goes to the errorResults function:
<SPAN class="keyword token">var</SPAN> printQLyr <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.xyz.org%2Fxxxxxx%2Frest%2Fservices%2FHBM%2FHBD%2FMapServer%2F3" target="_blank">https://www.xyz.org/xyz/rest/services/HBM/HBD/MapServer/3</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
printQuery <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
printQuery<SPAN class="punctuation token">.</SPAN>outFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Name"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
printQLyr<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>printQuery<SPAN class="punctuation token">,</SPAN> printQResults<SPAN class="punctuation token">,</SPAN> errorResults<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">printQResults</SPAN><SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> resultFeatures <SPAN class="operator token">=</SPAN> featureSet<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>resultFeatures<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">errorResults</SPAN><SPAN class="punctuation token">(</SPAN>message<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>message<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>This is the error message I receive (entirely unhelpful):
Error
at Object.A.m.load (init.js:1028)
at init.js:87
at c (init.js:103)
at d (init.js:103)
at b.Deferred.resolve.callback (init.js:105)
at c (init.js:104)
at d (init.js:103)
at init.js:92
at h (init.js:107)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Even when I run this in the ArcGIS JS sandbox, I receive this error. I receive this same error for any map service I try (I change the outField when I change the map service so I know that's not causing an error).
Additionally, if I add either a line like
printQuery<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"StateID = 'VA'"</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
or
printQuery<SPAN class="punctuation token">.</SPAN>objectIds <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
The query will run perfectly fine and return the records.
I can run the query in the REST API as long as I specify something in the "where" box or the "objectIds" box. If I specify nothing but an outField it will not return anything but I do not get an error message either.
How do I query all features in a dataset?
Feature layer settings:
