Is there a way to resize the tiles and have them show that way by default when using the dashboard theme in Webapp Builder? I am using the dashboard theme with the 9 tiles. I would like to make the map tile bigger by default when you first open the app.
Thanks!Pamela
hmmm, i don't seem to have those buttons!
Hey Pamela Locke,
You can use either of these two buttons:
Ben
Hi Ben,
Thanks for the Reply! Where do I find the "Modify Layout" button? I don't seem to see it on my screen....
Pamela
When you are configuring your dashboard you can click Modify Layout to add more dashboard panels/widgets but you can also resize the dashboard tiles in here.
I've added a short video as it was a bit hard to put into words.
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
