Got Error "Unexpected token <(…)" For Feature Attachment it is problem with my init.js. If i used <script src="https://js.arcgis.com/3.18/"></script> i got correct result.
<html>
<head>
<title>SanFrancisco311 - Incidents</title>
<link rel="stylesheet" href="http://xyz/arcgis_js_api/library/3.17/3.17/esri/css/esri.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; overflow: hidden; }
#map { height: 100%; padding: 0;}
#footer { height: 2em; text-align: center; font-size: 1.1em; padding: 0.5em; }
.dj_ie .infowindow .window .top .right .user .content { position: relative; }
.dj_ie .simpleInfoWindow .content {position: relative;}
</style>
<script src="http://xyz/arcgis_js_api/library/3.17/3.17/init.js"></script>
<script>
var map;
require([
"esri/map",
"esri/layers/FeatureLayer",
"esri/dijit/editing/AttachmentEditor",
"dojo/parser", "dojo/dom",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
], function(
Map, FeatureLayer, AttachmentEditor,
parser, dom
parser.parse();
map = new Map("map", {
basemap: "gray",
center: [80,18],
zoom: 8
map.on("load", mapLoaded);
function mapLoaded() {
var featureLayer = new FeatureLayer("http://xyz/Attachments/FeatureServer/0",{
mode: FeatureLayer.MODE_ONDEMAND
map.infoWindow.setContent("<div id='content' style='width:100%'></div>");
map.infoWindow.resize(350,200);
var attachmentEditor = new AttachmentEditor({}, dom.byId("content"));
attachmentEditor.startup();
featureLayer.on("click", function(evt) {
var objectId = evt.graphic.attributes[featureLayer.objectIdField];
map.infoWindow.setTitle(objectId);
attachmentEditor.showAttachments(evt.graphic,featureLayer);
map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
map.addLayer(featureLayer);
</script>
</head>
<body>
<div data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline'"
style="width:100%;height:100%;">
<div id="map"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'"></div>
<div id="footer"
data-dojo-props="region:'bottom'">
Click point to view/create/delete attachments.
</div>
</div>
</body>
</html>
